unearthing an old heap after 20years , flat tires, frozen drums etc
Discussion in 'The Hokey Ass Message Board' started by beaulieu, Sep 9, 2008.
  1. Shifty Shifterton
    Shifty Shifterton
    Til we know more, guess we'll just have to categorize beaulieu as a K car restorer and assume it's an Aries K convertible.
    (if that doesn't provoke full disclosure, don't know what will):D
  2. 8flat
    8flat
    Get a tractor...then lift very carefully. My coupe was down in the dirt at least 10 inches. Pulling it out would have put a lot more pressure on it.
  3. oilslinger53
    oilslinger53
    from covina CA
    so secretive! come on! what kind of car is it!? if you tell me what it is ill tell you the easiest way to get it out...
  4. beaulieu
    beaulieu
    from So Cal
    "Tell we know more, guess we'll just have to categorize beaulieu as a K car restorer and assume it's an Aries K convertible."
    OK.....its a K car :) I just love K cars , especially rustoleum flat black ones !
    yeah thats it , with racing stripes and flames..........
    its really a 6 banger RWD convert
    its not mine till its on the trailer and on the road, so I ain't saying nuthin :)
    Beaulieu
  5. Man, I really hope you're not stealing something out of a field, wouldn't be right.
  6. The37Kid
    The37Kid
    Smart people would rent a Skidsteer or mini excavator, and skip the caveman BS, what is this pile anyway?
  7. You have to lift or jack the car straight up, and fill in the ruts it was sitting into.
    A car with flat tires will skid easier if you have a junk hood to slip upside down under the front of it. But it's better to change them - don't even try to inflate the old ones.
    We've found they come out nice and easy if you can back a rollback up to them. Lift up with it, then pull it on a little at a time.
    As for pulling it from the back, that's probably a bad idea, unless the trees are huge and thick, cut them down, there's always the chance that they have roots growing into the suspension, too.
    But it really depends on the type of car, too, if it has a full frame, check it over for rot, if the frame is okay it should come out in one piece. Unibody can be another story. You may want to pull directly on the rear axle and not on the bumper or body.
  8. Ha, Ha, Could this be the James Dean car he stacked up so long ago?
    Great project...................................
  9. beaulieu
    beaulieu
    from So Cal
    no I am not stealing it......
    Beaulieu
  10. Ditto
  11. Good to hear that. Absolutely no use for thieves on this board.
  12. Get some chains or cables and attach to the front suspension if yuo are going to try to pull it backwards. You might get a couple of house trailer axles and wheels under it even one axle would be a great help. We use our wrecker dollies in this manner sometimes. Get a long hose with a snap on end to try and put air in the tires from a safe distance. Dont get in to big a hurry take yout time Good luck :D OldWolf
  13. Carpe Noctem
    Carpe Noctem
    from Las Vegas
    if theirs acess to a hose you might flood the ground a bit to help re soften it for removal. it'll pu less strain on the chasis and frame that way
  14. gas pumper
    gas pumper
    Doesn't everyone know a buddy with a backhoe?
    An operator and a couple of chains. Very versitile machines. A good operator can do magic with a backhoe.
  15. Jarred Hodges
    Jarred Hodges
    I have done this before. We would dig out from under it to put a jack under it. If the drums won't turn take them off, then put some wheels with aired up ties on and pull it out
  16. Abomination
    Abomination
    And I hope that you are. Steal it. Steal that M'r F'r. Steal it now...
    :D
    ~Jason
  17. Abomination
    Abomination
    Well... damn. :(
    Not even "creative borrowing"?
    ~Jason
  18. oldsman71
    oldsman71
    maybe its a vette!!!
  19. oldsman71
    oldsman71
    hopefully not a chevette!!!!!! with the roof sawed off, and longer fenders fer the 250 chevy 6. lol!!!!!!
  20. 41woodie
    41woodie
    Aw common admit it's a 356, if it is I can tell you from experience that you should cover it with dirt and forget it. They don't have a frame just a VW-like pan, and instead of being bolted onto the pan like a VW they are welded on. Parts for 356's aren't cheap, even a cabriolet like what that appears to be would be a money pit of biblical proportions.
  21. beaulieu
    beaulieu
    from So Cal
    its not the car on my post ( I wish it was ! ) , its a 6 cyl , rear wheel drive convertible 3000 pound beast ,
    so no reason to speculate because I am not telling :)
    I know many have dug out cars much worse (and deeper) than this , just trying to get some other iideas I have not thought of ,
    I might try a backhoe to lift it up so I can get something solid under the wheels,
    I just do not know anyone around there with one......
    Anyway if you have any other ideas let me know ,
    Thanks Beaulieu
  22. henry29
    henry29
    Could be an early sixties mercedes 300 sl convertible.:D
  23. Abomination
    Abomination
    LOL!
    Is it this?
    http://blog.hemmings.com/index.php/2008/05/16/gonna-hit-the-lakes-with-my-porsche/
  24. toddc
    toddc
    Big tyres are great on soft ground. I also found that a crowbar with a chisel end is much better for smashing off brake drums (sometimes they just wont come off) than a hammer. If its really buried, one of those inflatable bag type jacks like the 4x4 guys use might be good, the ones that you connect to an exhaust pipe.
  25. Dyce
    Dyce
    What I've done with frozen drums is cut em with a torch. Just go right around the hub so the drum sits there and the hub spins inside. If they are sitting in the dirt you will most likly ruin the drums before you ever got them off, or freed up. Otherwise a shovel, a jack and wood to set the jack on so it dosn't sink.
    Good luck!! I'm jelous. I love a good scrounging trip....
    Jeff
  26. Front drums you can usually get off, by removing the outer wheel bearing and nut, and worrying them loose. Unbolting the wheel cylinders (or busting the bolts right off) also gets you some wiggle room. Rears are tougher, I've never gotten rears off without wrecking them. A cutoff wheel in a grinder can help cut through especially the ones where they're a cast wear surface on a steel face.
  27. willowbilly3
    willowbilly3
    from Sturgis
    I need some help with this but I can't tell you what it is because it's a secret.
  28. Toqwik
    Toqwik
    (1)Go to a mobile home dealer and borrow a set of trailer axles. Jack it up, slid em under, and go home. or,(2) take 2 railroad ties, cut ends like a sled runner, drill hole on runner end. Jack car up, place runners underneath, take chain thru the hole in the runners. put a piece of pipe to keep them from pulling together. (3) get some 2x10's and some motor oil, make em slick and pull
  29. ALindustrial
    ALindustrial
    hahahaha...
  30. jusjunk
    jusjunk
    from Michigan
    I believe Bruce has done this before.. I didnt look but i think he has all his fingers yet ?:D:D:D:D
    Dave
