Projects uni-body
Discussion in 'The Hokey Ass Message Board' started by 440+6, Apr 19, 2016.
  1. squirrel
    The problem I had when looking at the frame connectors, is the attaching points...I didn't see how they were going to add any stiffness. They seem to connect the wrong things together.
    Being an engineer messes up one's perspective, I guess.
  2. Joliet Jake
    Joliet Jake
    from Jax, FL
    Oh, and go ahead and replace that stock rear end. I destroyed mine, split both axle tubes wide open wrecking the drive shaft in my 62 with a worn out tired small block. I installed a 67 Chevy II 12 bolt posi, problem solved! Good luck with your project!
  3. LOL you really only need them if you hook up.
    Actually a true "Sleeper" probably would not have a roll bar or cage. They only street race, once you roll into the water box you have lost sleeper status.
  4. town sedan
    town sedan
    ...if you really want to mess with peoples heads why not an OHC Pontiac six? Not enough? Put some pressure on it with a turbo. Would be fun to tell the guy you cleaned his clock with a banger. Now that's a sleeper in my book.
    -Dave
  5. saltflats
    saltflats
    from Missouri
    A nice 327 4 speed and a early Pont rear with some 4.88s
    Put me in the 10s
    town sedan likes this.
  6. town sedan
    town sedan
    Also, sleepers don't advertise. Make sure you have plenty of room for mufflers and pipes.
    -Dave
  7. Jalopy Joker
    Jalopy Joker
    be sure to dress like a straight arrow Geek - both car & driver have to look the part
  8. town sedan
    town sedan
    Don't for get your slide rule and pocket protector!
