Technical Universal / Rag joint head scratcher
Discussion in 'Traditional Hot Rods' started by AGELE55, Dec 15, 2020.
  1. AGELE55
    AGELE55
    Yes. I counted splines, but now I'm wondering if it was the right package with the wrong universal? I verified the p/n on the package but can't say I ever physically verified the p/n on the joint itself. Also I measured the ID with a dial caliper and came up 1/64" short. Borgeson rep said the caliper probably wasn't seating all the way, but now I'm wondering.
    I just ordered a new one. Fingers crossed.
  2. nobby
    nobby
    did the 605 exist prior to 1978
    Lloyd's paint & glass likes this.
  3. AGELE55
    AGELE55
    ?? I don't follow ya..
  4. seb fontana
    seb fontana
    from ct
    Checked for joint, found stuff I should throw out, so no help.
    AGELE55 likes this.
  5. seb fontana
    seb fontana
    from ct
    According to above list it started in '78. I took one out of a '78 Lemans.
  6. AGELE55
    AGELE55
    Update:
    I ordered and received a second Borgeson universal on the off chance the first one was mis-packaged or mis-made. No joy. Close examination makes me think the universal and gearbox are both 3/4-30 spline, but with zero tolerance. It’s like a force fit application.
    I surrender. I cannot find a universal to fit, but rag joints do fit because they have a little give, but can’t find one with a smaller overall diameter.
    Today I will piece together parts from three different rag joints a make a Frankenstein to do the job.
    seb fontana likes this.
  7. My 57 has a 605 box on it and it's coming off. Based solely on what I've learned about them from this joint and tri five.com. i don't want headaches just to have power steering. From what I've been taught by the tri five gurus of the world, buy the borgeson box.
  8. Happydaze
    Happydaze
    Sounds strange. It might not be of any help but Maval Unisteer list universals which have a split in the body and a pinch bolt .
    They list a mul***ude of joints.
    Chris
    Sent from my SM-T515 using The H.A.M.B. mobile app
    AGELE55 likes this.
  9. It is a good thing that you posted your problem, because I have a tilt column with the rag coupling that I am intending to install on my Cameo. Now, I'll know where to look for the parts I need.
    At this point, I am still planning to stick with my 57 steering box, because it is still in excellent condition. I am also planning to install the older, ram type steering ***ist, that was used on the early trucks and the Corvettes. I have all the parts, but I have to make an adapter to mount the hydraulic pump.
    Bob
    AGELE55 likes this.
  10. RMR&C
    RMR&C
    from NW Montana
    AGELE55 likes this.
  11. BamaMav
    BamaMav
    from Berry, AL
    Chevy Astro vans have a shaft with two U joints in it that might work for you.
    AGELE55 likes this.
  12. I've installed a few where I had to tap them on. Wasn't a slip fit, wasn't a press. Somewhere in between .
    seb fontana and AGELE55 like this.
  13. AGELE55
    AGELE55
    Lol..I definitely exceeded the threshold for “tapping“ it on.
  14. AGELE55
    AGELE55
    The only thing that fits the 605 box so far is a pinch bolt rag joint, but of course, it’s unobtainable in the smaller diameter with the correct spline combo.
    I have begun building my own rag joint. I’ll update later today.
  15. AGELE55
    AGELE55
    Final solution-
    I scavenged a pinch bolt fitting from a
    3 3/8" rag joint with the correct spline count and welded the holes closed. I redrilled the holes to fit a 2 3/4" rag joint with the correct spline count on the other side. I then ground off the outer diameter to fit inside it's new home.
    Sounds pretty easy, but took me a while to get here.
    Still don't understand why the Borgeson parts don't fit, but life goes on and I need my shoebox back on the road.
    seb fontana, Algoma56 and RMR&C like this.
  16. lostone
    lostone
    from kansas
    Great job at actual backyard hot rodding at its finest!!
    Back to its roots, seriously I love watching people actually figure out a problem, build the parts, install it and make it work!
    Great job!
    RMR&C and AGELE55 like this.
  17. That will work! Good thinking.
  18. seb fontana
    seb fontana
    from ct
    Glad you built the solution! Don't shoot me but I just found a 2-1/2" rag jiont that fits a 605! Actually 2.. I posted the other day that I looked, and I did; right at them but didn't see them..o_O
    AGELE55 likes this.
  19. AGELE55
    AGELE55
    Oh sure....NOW you find them...lol
  20. seb fontana
    seb fontana
    from ct
    **** I do the same for myself!!
