Hot Rods Unknown truck cab
Discussion in 'The Hokey Ass Message Board' started by propwash, Oct 30, 2016.
  1. propwash
    propwash
    from Las Vegas
  2. 117harv
    117harv
    International
  3. squirrel
    46 international, maybe?
  4. 52lomofo
    52lomofo
    International
  5. gimpyshotrods
    gimpyshotrods
    I'd have to guess 1941 International.
  6. propwash
    propwash
    from Las Vegas
    I was thinking 42 International, but we all know how long trucks hold onto styling cues. Thank you all for your knowledge and your willingness to share it.
  7. rusty1
    rusty1
    41-49 IH
    38fordpickup and Hnstray like this.
  8. Mr48chev
    Quite similar to this 48 [​IMG]
    Or this 41
    Wouldn't be a bad basis for a slick little bobber style truck.
  9. D, K or KB series IH. first built in '37. Could be from up to a 2 ton truck, they all shared the same cab
  10. Haybaler wasn't into annual model changes. With Internationals, more accurate to talk about series than model year. The KB series was built '41-'49, and the only difference between a '41 and a '49 is that the '41 is 8 years older, a little bit of trivia is that door latches are the same as '38-'47 Ford trucks. Outside and inside door handles are the same as '38 Ford Standard car and '38-'47 Ford truck.
  11. Engine man
    Engine man
    from Wisconsin
    At work we had a 72 model roll off truck and that looks like the same cab.
  12. Engine man
    Engine man
    from Wisconsin
    I believe the correct reference is Corn binder.
  13. Terraizer
    Terraizer
    That is a 1941-49 1/2 ton to 1.5 ton cab. 2ton and larger used the 1937-40 D series cab and that is not one. K's 1941-46 have vin tag on the DS kick panel, inside the cab. Kb's 1947-49 have the vin tag mounted on the upper firewall, otherwise pretty the same 41-49
  14. King ford
    King ford
    from 08302
    how bout "13 letter **** spreader!"
