Hot Rods Unobtanium shift indicator Q's
Discussion in 'The Hokey Ass Message Board' started by Turbo26T, May 24, 2026.
  1. Turbo26T
    Turbo26T
    IMG_0259.jpeg IMG_2294.jpeg IMG_2293.jpeg I've posted and looked for this Fordomatic shift indicator for a long, time..There seems to be no one who has one or at least no one who will answer my inquiries ...Mine is cracked and I've successfully epoxied it back together , but I'd like a better one...evidently I'm the only person on the planet needing one...It’s an early ‘50-‘51 two tube Fordomatic column
    So ,
    1. You got one you'll sell ?
    2. I can easily make one out of flat plastic sheet. The problem is the lettering
    How /Where/Who could do that ??
    Stan
    Ziggster and chryslerfan55 like this.
  2. ronzmtrwrx
    ronzmtrwrx
    You might get someone to 3D print one and recess the letters on the back side. Then you could easily fill in the letters with white paint.
  3. Squablow
    Squablow
    Is there 3d printing media that can do crystal clear plastic? I'm honestly not sure. I'd probably try to carve that shape out of a piece of flat acrylic and just figure out how to get the lettering on the back.
  4. Try a place that makes nametags, other laminated labels and trophies/awards. The better places will have a computer operated machine that will 'flip' the lettering if need be or just scan it. Worst case, buy some silicon rubber mold material, take a mold off that one, then resin cast a new one. Might even be a business opportunity!
    olscrounger, Oneball and jimmy six like this.
  5. ronzmtrwrx
    ronzmtrwrx
    Yep. This is a better idea than the 3D printing approach.
  6. Turbo26T
    Turbo26T
    Thanks for all the replies and suggestions...
  7. BJR
    BJR
    Maybe get some metal stamps and heat them up a little and melt the letters into a sheet of plastic.
  8. Ziggster
    Ziggster
  9. patsurf
    patsurf
  10. A modern, well equipped sign shop should be able to reproduce this. Most of the good shop are busy though, so it might be tough to pry them away from the work they do all day to make a single piece like that. If you have a shop like that in your area, try to someone there and see what they can do.
    alanp561 likes this.
  11. Moriarity
    Moriarity
    SUPER MODERATOR
    acrylic is super easy to work with. there are places that sell small pcs so you won't need to buy a full sheet. cut it to shape, sand the edges smooth and polish the edges. then get some reverse cut vinyl letters cut and put them on the back side. Is this car a stocker? if not heres your chance to make something cool
    Squablow, 31Apickup and rusty valley like this.
  12. 49Olds
    49Olds
    Resin casting is pretty easy. Your part would be simple. Done a bit of it for my vintage bikes. Lots of videos on YouTube and cheap kits on Amazon.
    Damon777, skooch and alanp561 like this.
  13. Turbo26T
    Turbo26T
    Moriarity : Not a stocker..Actually its a very interesting column build I put together for my Model A Coupe project...' '51 Fordomatic column (first year with t/sigs in column ) to control a 2004R , '40 Ford stg. wheel ( To get horn in center of wheel , taper mount hollow shaft with Jeep horn contact in tube jacket )...
    As far as the indicator...Somewhere in boxes of build supplies Ive ac***ulated , there's a really nice unbroken original indicator...But dang if I can find it..So I'm stuck restoring the broken one I have til I stumble across the misplaced one..
    Thnaks for your input
    Stan
  14. Jack E/NJ
    Jack E/NJ
    from NJ
    Rule of thumb. You'll find it only after you've restored the broken one AND made a reproduction.
    alanp561, BigRRR and Ziggster like this.
  15. Joe H
    Joe H
    Any computer controlled wood router should be able to cut the letters pretty easy with the right size bit. I see them on you tube all the time carving out out stuff.
  16. ClayMart
    ClayMart
    Look for a laser etching or engraving shop in your area. Trophy shops, sign shops, or anyplace that makes personalized gift items. Like gl***ware or drink tumblers with engraved names. It looks like there might be a couple shops in your area. They might be better suited to doing one-offs or short runs. There's even some tabletop laser cutters offered online for surprisingly little money. Don't know how well they might work for your needs though.
  17. Damon777
    Damon777
    I came here to suggest this. I 3D printed a 1/2 Scale Buick 401 piston and used it as a pattern to make a mold with food safe silicone. Now I enjoy old fashioneds with 1/2 scale nailhead ice cubes. If I can mold with water, I could use the same mold with acrylic resin.
    alanp561 and 49Olds like this.
  18. 49Olds
    49Olds
    Taillight lenses, dash knobs, door lock pulls, etc. all super easy and cheap.
    Damon777 likes this.
