Hot Rods Unsplit bones with a spacer.
Discussion in 'The Hokey Ass Message Board' started by lothiandon1940, Aug 4, 2015.
  1. Anderson
    Anderson
    This is what we did on a ‘34 roadster at work. It needed the oil pan clearance on a later Flathead with a two-piece pan. But between the spacer and lowering the car so much, still had to cut the wishbones to bring the caster back from 8.5 to 6.5 degrees. It had been very hard to steer at lower speeds or in a parking lot. Even with an F1 box.
    Dan Hay and lothiandon1940 like this.
  2. ct1932ford
    ct1932ford
    I found what I was looking for. Mac's Speed in New Zealand. Thanks All!
    Kiwi 4d and lothiandon1940 like this.
  3. krylon32
    krylon32
    from Nebraska
    You have any pictures of what you purchased? What's their website address?
    lothiandon1940 likes this.
  4. slug
    slug
    I think an unsplit wishbone always works smoother than than split bones if you can make it happen.
    lothiandon1940 and alchemy like this.
  5. Don, when I raised the front of my car for the g***er look, the caster went crazy, negative. I built a spacer about 4.5 inches high. Just lucky on my part, my uncle had a piece of plate in his stash, that someone had made a nice round divot in. I started with that. I now have about 5° positive caster. Gene.
  6. ct1932ford
    ct1932ford
    https://www.macsspeed.com/ [​IMG][​IMG]The other photo did not come up
    lothiandon1940 and Anderson like this.
  7. krylon32
    krylon32
    from Nebraska
    Looks good, is the price in US dollars and was shipping expensive?
  8. Dan Hay
    Dan Hay
    If your car sits at a rake you might have a net of zero change in caster.
    I had splits bones on my 40 with the CE brackets that hung down of the X member about 2-3”. It drove great, so I wouldn’t worry about 1*. It had 7*.
  9. 325w
    325w
    Did something similar years back. Didn’t realize how ugly it was till I drove over to a guys house. His comment was. What the hell have you done!!!
  10. ct1932ford
    ct1932ford
    Yes, US dollars. I bought two. Pm me!
  11. ct1932ford
    ct1932ford
    I was trying to figure out why my coupe steers hard when maneuvering a parking spot etc.
    I think this is the issue. After checking my caster. We will see! I’m using a 56 Ford pickup box that is all new.
  12. Makes sense to increase the caster by adding the wishbone dropper. Does your car steer better now?[​IMG] [​IMG]
    Have you checked MAC's Spped new website? Much easier to navigate now.
  13. 40ragtopdown
    40ragtopdown
    FB_IMG_1681051825660.jpg FB_IMG_1681051793412.jpg FB_IMG_1681051837844.jpg FB_IMG_1681051804557.jpg Not as pretty as store bought but this will also work. Just two wishbone cups and some heavy wall tubing.
  14. lothiandon1940
    lothiandon1940
    Back up for continued consideration.
  15. jimvette59
    jimvette59
    Does 1 * = .170 per foot ?
  16. Ebbsspeed
    Ebbsspeed
    If you have a segment one foot long, leaving one end at a fixed point and dropping the other end of that segment 0.209 inches will equal 1º.
    A circle with a 12" radius has a cir***ference of 75.4". Divide that cir***ference by 360º nets a change of 1º equaling 0.209.
    Tell me the length of your wishbone from the center of the perch bolt to the center of the wishbone ball and I can tell you how many degrees it will change based on whatever drop you tell me. OR, tell me how much more caster you want and I can tell you how far to drop the ball.
  17. Phil Brown
    Phil Brown
    And how many of us in school said "I'll never use this kind of math in real life" :eek:
    AVater and lothiandon1940 like this.
  18. Ebbsspeed
    Ebbsspeed
    That was me for sure. And as usual, I was wrong. I had to figure out the math stuff long after I got out of school.
    Phil Brown and lothiandon1940 like this.
