Unusual engine photos
Discussion in 'Off Topic Hot Rods & Customs' started by William Thompson, Sep 28, 2018.
  1. 1947knuck
    1947knuck
    TBirdGirl26, loner2, Stebo27 and 8 others like this.
  2. swade41
    swade41
    from Buffalo,NY
    Not that unusual, hot rod Lincoln Screenshot_20181013-195116_Photobucket.jpg Screenshot_20181013-195139_Photobucket.jpg Screenshot_20181013-195204_Photobucket.jpg
    loner2, Stebo27, loner1 and 8 others like this.
  3. Here is a low tech engine, my Easthope Marine, 3 cyl 30/40 hp. 40 hp at 720 rpm. Built in Vancouver in 1947.
    41 GMC K-18, loner2, Stebo27 and 7 others like this.
  4. tb33anda3rd
    tb33anda3rd
  5. tb33anda3rd
    tb33anda3rd
  6. tb33anda3rd
    tb33anda3rd
  7. tb33anda3rd
    tb33anda3rd
  8. loudbang
    First one is a Fiat
    this one goes with the white car behind it.
    loner2, Stebo27, loner1 and 6 others like this.
  9. bostonhemi
    bostonhemi
    325 Dodge Poly
    Deuces likes this.
  10. RichFox
    RichFox
  11. 1947knuck
    1947knuck
    Rajo OHV Early Ford 4 cylinder Conversion Head. Santiago-RAJO-head-700x700.jpg
    TBirdGirl26, loner2, Stebo27 and 7 others like this.
  12. 1947knuck
    1947knuck
    TBirdGirl26, j-jock, loner2 and 7 others like this.
  13. 1947knuck
    1947knuck
    Riley OHV Conversion Early Ford 4 Cylinder Mark-Mccann-Riley-OHV-top-small1.jpg
  14. RichFox
    RichFox
    M&B Dodge Bros..jpg Morton & Brett OHV conversion on '26 Dodge Bros. M&B Dodge Bros..jpg
  15. RichFox
    RichFox
    loner2, Stebo27, loner1 and 7 others like this.
  16. Rich..that Morton & Brett Dodge conversion.....any more info?..is it a recent conversion.I say that only because of the style of rocker cover but either way it looks interesting.........and the Stevens conversion is especially nice......there are a few pics of it in various early 50's books I have.......with all the late pieces on the engine I'm****uming that it ran recently........how did it go?..........thanks for the pics BTW.............Andy Douglas
  17. bobbytnm
    bobbytnm
    Awesome thread!!
  18. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    That is a Vertex magneto running through a right-angle gearbox, with provisions for a mechanical tach drive and mechanical rev limiter. In a stock 300 Ford the intake is on the right (passenger) side of the engine. But when I moved the intake over to the left (driver) side it crashed into the distributor. So I made this right angle gearbox using two Boston bevel gears (# HLK 101Y) to lay the magneto down. I painted a spiral on the mag shaft so it was readily visible when running.
  19. RichFox
    RichFox
    You have no idea how much time I had in the M&B rocker box. And it was still junk. Lots of JB Weld by the time that picture was taken. The head is original from the early 30s. The Stevens OHV ran good, 173.253 on gas in a odd looking Comp Coup at El Mirage as I remember.. A few M&B pics. img166.JPG img169.JPG
    loner2, Stebo27, j-jock and 3 others like this.
  20. Rich.......you'll have to excuse my ignorance but is that M&B head made up of two pieces?........I'm trying to work out exactly whats what comparing your original engine pic that shows it painted yellow and the pic showing it in the original cast iron.............you have me intrigued............lol...........can you explain the port arrangement as I can't work out if its an F head or normal OHV intake & exhaust...........lol...........could you shed more light on the subject, please...........lol.....thanks, andyd
  21. RichFox
    RichFox
    The above picture is the head exhaust side on a 26 Dodge Bros block. Pre "Fast Four" Note the block has only 4 exhaust ports. No longer used after conversion to OHV. Single intake on the other side. As you can see from the combustion chamber photo, it is not an F head. The picture in the car, painted yellow, is the intake side, Here is another picture of the head on the bench when I was working out rocker arms for it. Three exhaust ports two intakes on the other side. img171.JPG
  22. RichFox
    RichFox
    img168.JPG img168.JPG Intake side. Note the single intake port or the original flathead Dodge configuration. Also all the brazing I did to repair the freeze crack in the block. Four holes below the OHV intake ports are for spark plugs.
    One off hand built for the Stutz Black Hawk LSR used at Daytona Shores by Frank Lockhart, later used at Indy
  24. Rich.....thanks.....makes sense now............andyd
  25. 1947knuck
    1947knuck
    Alexander OHV Flathead Conversion, Dual Winfield "SR" Carburetors. img8146_orig.jpg img8144a_orig.jpg
  26. 1947knuck
    1947knuck
    Arrow Aircraft OHV Ford Flathead Conversion, It featured individual port fuel injection and a Harmon&Collins magneto. img8117_1_orig.jpg dscn1033_orig.jpg dscn1035_orig.jpg
    Nobey, TBirdGirl26, loner2 and 12 others like this.
  27. 1947knuck
    1947knuck
    Tornado OHV Ford Flathead Conversion. It featured custom seperate intake manifolds, The heads could be ordered in compression ratios from 7:1 up to 16:1. In 1950 one of these engines ran 175mph at Bonneville in a streamliner. 77-0011-3_orig.jpg 77-0011-8_orig.jpg 77-0011-1_orig.jpg
    TBirdGirl26, loner2, Stebo27 and 9 others like this.
  28. Fordors
    Fordors
    More on the Fronty-Fords, and the author snuck in some details on other engines too. Part One did not document any engines. Scan_0125.jpg
    Scan_0126.jpg Scan_0127.jpg Scan_0128.jpg Scan_0129.jpg Scan_0130.jpg Scan_0131.jpg Scan_0132.jpg
    loner1, j-jock, tinsled and 6 others like this.
  29. Fordors
    Fordors
    How about the George Riley SOHC V8 Ford? Ford Engineering refined Riley's design and built a few of their own in like fashion that were run on the dyno and even tested in cars. It was rumored that a few found their way to Argentina and were run in race cars. On a side note, it bothers me when people spell the name of Kenny Harman wrong like the author did here. Harman was a gifted mechanic, machinist and cam grinder. Scan_0086.jpg Scan_0087.jpg Scan_0088.jpg Scan_0089.jpg
    treb11, BigO, Deuces and 3 others like this.
  30. Fordors............thanks for the info & pics.........Strange that the Frontenac article doesn't mention the Frontenac DOHC Stagger Valve arrangement................have seen a couple of pics of them over the years and they would get my vote as the ultimate T engine conversion.............tho' to be honest any OHV/C conversion would keep me quite for a while.......thanks.......andyd
