Unusual engine photos
Discussion in 'Off Topic Hot Rods & Customs' started by William Thompson, Sep 28, 2018.
  1. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    That is an interesting pic. In studying the front gear drive it appears each bank of cylinders has its own magneto to fire the plugs. What I don't get is it looks like they are driven 1:1 with the crankshaft, meaning each plug must have been firing on every revolution? I know some coil-on-plug modern systems do this too - called a "lost spark system" sometimes. Is that what I'm seeing? Once again I'm reminded that as far as engine design goes nothing is "new".
  2. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Don't know about the Fiat but Harleys used 'lost or wasted spark' since Moses was a youngster. :D
    Boneyard51, Deuces and loudbang like this.
  3. RichFox
    RichFox
    Posted before. Recent repop of Stephens heads. Has run well in SCTA events. Original were iron. New ones are a lot lighter.
  4. XXL__
    XXL__
    Wasted spark systems are actually pretty common-- the Mitsubishi 4G63 (think early turbo Eclipses... I used to campaign a 600ish hp AWD car many years ago) a number of Mercedes 6's, the Buick 3800, Harley twins, and going way back to 1940's Citroen 2CVs. It is also a common 'simplification' to home-built distribution systems as the spark signal is easier to time... piston up, light the match. I think of it as "reasonable laziness" engineering.
    chryslerfan55, loudbang and Ned Ludd like this.
  5. Ned Ludd
    Ned Ludd
    And, of course, pretty much every pre-computerized motorcycle.
    chryslerfan55, loudbang and XXL__ like this.
  6. Ned Ludd
    Ned Ludd
    That's got a rather Teutonic bulbousness about it. It looks like something BMW might have built in 1954.
    Here is what BMW actually did build in 1954:
    loner2, Stebo27, loner1 and 7 others like this.
  7. XXL__
    XXL__
    Funny. My first impression when I saw it was some fat German tinkerer adapted a pie pan or something from the bakery he runs, then threw on a couple of wingnuts from the junk drawer to hold it on.
    Next, I thought of these very common (in colder climates) thing. Simple, ugly, but functional...
    loner2, Stebo27, Bleach and 4 others like this.
  8. 1947knuck
    1947knuck
    TBirdGirl26, loner2, Stebo27 and 6 others like this.
  9. 1947knuck
    1947knuck
    Hendee 8 cylinder water cooled engine built by Hendee Manufacturing, builders of Indian Motorcycles. tumblr_n8kf5s2V3E1tc5lyxo1_1280.jpg
    TBirdGirl26, loner2, Stebo27 and 11 others like this.
  10. Let me just say that I know motorcycles are taboo here, but this ones got an interesting power plant. IMG_0436.JPG
  11. Jimmy2car
    Jimmy2car
    from No. Cal
  12. loudbang
    Ardun
    Flatty overhead conversion
    loner2, Stebo27, loner1 and 8 others like this.
  13. Deuces and loudbang like this.
  14. earlymopar
    earlymopar
    That's a beauty for sure. Was this something that was used in midgets or other dirt track cars?
    - EM
    loner2, Stebo27, loner1 and 5 others like this.
  15. loudbang
    Don't know it was before my time :rolleyes:
  16. 1947knuck
    1947knuck
    Daimler-Benz LOF-6 16 cylinder engine. This is the type of engine used in the Hindenberg. lz129-diesel-web.jpg
    TBirdGirl26, loner2, Stebo27 and 7 others like this.
  17. 1947knuck
    1947knuck
    1928 Dual 91 ci inline 8 cylinder engines using 2 cranks in a common crankcase. tumblr_ni5cxnpZtg1rn8k76o1_1280.jpg
    TBirdGirl26, loner2, Stebo27 and 8 others like this.
  18. drtrcrV-8
    drtrcrV-8
    Earlymopar : Based on the photos behind the engines & displacement limits They were used in Sprints & not in Midgets.
  19. sliceddeuce
    sliceddeuce
    chryslerfan55, Deuces, XXL__ and 2 others like this.
  20. loudbang
    Fronty Conversion
    Hal Indy
    loner2, Stebo27, loner1 and 3 others like this.
  21. X38
    X38
    You forgot Hal Midget.:rolleyes:
    chryslerfan55 and Dean Lowe like this.
  22. Speedwrench
    Speedwrench
    Possibly the Studebaker done for J C Agajanian Indy effort in the early fifties ? The engine never actually made it to Indy.
  23. Bleach
    Bleach
    I think most of the engines were salvaged and preserved. They're on display at a few museums. They are huge, about 5400 cubic inches. They were diesels that put out over 1300 hp.
    1947knuck, chryslerfan55 and loudbang like this.
  24. Road Runner
    Road Runner
    Love the look of this proposal from the streamline era.
    Like a Buck Rogers 1939 movie prop.
    Crosley 1702 cubic inch X-24 Defender
    On May12th 1942 a report was submitted to Ray Olson Jr of the Navy Department proposing an all new 24 cylinder aircraft engine, designed by Taylor Engine of California (3 man team). This would be a fabricated block construction on a tubular one piece crankcase with 7 mains engine using ideas developed by Daimler and Mercedes-Benz in the early years of the automobile as well as the 27 liter Liberty V-12 aircraft engine during WW-1.
    Four 6 cylinder banks 90 degrees apart.
    HP estimated from the 950-1050lb package:
    Un-Supercharged 1000 HP
    Supercharged 32 In.* 1,250 HP
    Supercharged 39 In.* 1,600 HP
    Supercharged 48 In.* 2,000 HP
    *Manifold pressure in inches of mercury(hg).
    The overall size with tapered nose for the prop and the rear accessory drive ***embly was 76 inches and 45.5 inches in diameter. It was interesting to look at the drawings and see if the front nose and rear ***embly was removed, the engine was almost a perfect cube and would have fit in a 36 X 35 inch box.
    Proposed for aircraft use but for any use where space and weight was a important.
    There is no indication that the X-24 was ever built.
    Source: http://crosleyautoclub.com/EngineTree/Crosley_Eng_Tree.html
  25. 1947knuck
    1947knuck
    I have no idea what type engine this is it just has such a cool look to it. 610px-1903_premier1.jpg
  26. 1947knuck
    1947knuck
    TBirdGirl26, Ned Ludd, loner2 and 6 others like this.
  27. XXL__
    XXL__
    1903 Premier. It was a pentroof head hemi head design. It was also OHC, which is completely exposed up top, and the crank and rods were exposed at the bottom. Yikes.
    loner2, Stebo27, loner1 and 4 others like this.
  28. scruff
    scruff
    Pretty sure those are Birner heads on a flatty,one of very few sets. The stude Indy effort was dohc.
    Sent from my SM-G920T using The H.A.M.B. mobile app
    Speedwrench and loudbang like this.
  29. seb fontana
    seb fontana
    from ct
    Well that must have used/spit oil every where!
  30. 1947knuck
    1947knuck
    I don't know what year this Comet was built or raced but here's a picture of the engine and the car. comet10-760x571.jpg comet-12-760x626-760x626.jpg
