Unusual engine photos
Discussion in 'Off Topic Hot Rods & Customs' started by William Thompson, Sep 28, 2018.
  1. Fordors
    Fordors
    ACF02887-C03D-435F-9DD1-D96F9B1CB764.jpeg BA669A0B-B9B1-4BE6-941B-E5174B95CDC1.jpeg 672D75DE-492F-4FCD-89A8-C200052BAAAC.jpeg 6B81D1F4-5482-47D0-9910-8B046EC93591.jpeg 9EA386F9-7477-4E58-BFAF-5FDF354D3610.jpeg The Barker, designed by Bob Barker.
    Credit to Laurence Deutsch for research into the Barker engine history.
    Jet96, wicarnut, mgtstumpy and 14 others like this.
  2. drtrcrV-8
    drtrcrV-8
    Please also post this in the midget thread, if you haven't already. Thanks!
    Thor1 likes this.
  3. something a little different
    J
  4. mgtstumpy
    mgtstumpy
    Jet96, wicarnut, Thor1 and 9 others like this.
  5. Fordors
    Fordors
    I've seen plenty of Offy's but never noticed one with this oversized crankcase breather before.
    Scan_0253.jpg Maybe a little too much nitro in qualifying? I think a lot of teams snuck in 10-15% BITD.
    Jet96, wicarnut, Thor1 and 6 others like this.
  6. Jalopy Joker
    Jalopy Joker
  7. mgtstumpy
    mgtstumpy
    Davies produced 10 of these DOHC flathead conversions
    I stumbled onto these, possibly an ***embled Davies or Ansen conversion. Below engine does not have a belt drive yet mock up does?
    Ansen conversion in lower left foreground with drive, were they the same as Davies conversion, no knowledge? Below picture depicts gear drive set-up. Note a young Ed Iskenderian on the far left of the group!;)
    Jet96, RMR&C, Ron Funkhouser and 13 others like this.
  8. Fordors
    Fordors
    I ran across a photo of a similar engine with different carburetors, it was ID’d as a Chris Craft Model M, 130 hp, built by Hercules.
    Deuces, Thor1 and loudbang like this.
  9. Fordors
    Fordors
    B2241D4E-554F-473C-B397-BBA9A6F3EF0A.jpeg 73E53FED-DD6F-46FA-852A-621940BFC088.jpeg
    The first photo is Joe Lencki’s Gallivan, but instead of using a Model T block as was customary Joe designed and had his own block cast. It ran at Indy in 1935, went out with a bad valve.
    The other engine is a 248 cu. in. Morton-Brett. In qualifying at Indy in both 1937 and 1938 it was waved off for having insufficient speed, never to be seen again.
    Jet96, Deuces, AmishMike and 7 others like this.
  10. saltflats
    saltflats
    from Missouri
    Spring in the port :confused:
  11. ottoman
    ottoman
    from Wisconsin
    Looks like the intake manifold and updraft carbs are below the openings that you can see the springs in... they look like access openings and would be above the intake ports
    Fordors, Thor1, egads and 2 others like this.
  12. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Promotes swirl!
    seb fontana, Thor1, saltflats and 2 others like this.
  13. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Is anyone else frightened by the thumb-screw hose clamps on the oil and water lines on the Lencki engine?
    loudbang and Thor1 like this.
  14. Fordors
    Fordors
    Yes they are thumbscrews but there’s nothing to prevent one from tightening them a bit more with pliers. How about the wire clamps on this 1926 Indy entry, with an engine by Ernest Eldridge of Great Britain? This was a common clamping method and even the Duesenberg brothers did this early on.
    Boneyard51, Jet96, Deuces and 3 others like this.
  15. noboD
    noboD
    How ever did I miss this thread? Here's one for the thread, a Dodgeson rotary valve engine built around 1923. It was built by a son of one of the Dodge Brothers' sons. He tried to build his own car but was not very successful.
    Jet96, Deuces, Fordors and 3 others like this.
  16. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Interesting pic Fordors. Is that an oil cooled / lubed steering box?
  17. wicarnut
    wicarnut
  18. wicarnut
    wicarnut
    The Military has always invested into various development of engines for their various applications. I had a customer for 30 years and that was his entire business, some the most interesting work I did, I built many interesting projects that I'd like to talk about, but this type of work came with a confidentiality clause, we turned in all tooling/drawings/parts/concepts/cad cam computer files/etc. After a project was completed, Twilight Zone, Gone [​IMG]
    Deuces, MO54Frank, egads and 2 others like this.
  19. wicarnut
    wicarnut
    Love this Thread, It shows that near every design concept in engine engineering has been done, many from way back in the day. Our modern electronics combined with technology produce engines with unbelievable power and economy. I put up pictures of my build project completed and used in compe***ion 1984-1986, still have, expensive paperweights. I was racing Midgets, using VW style racing engine, as far as I Know, the only liquid cooled cylinder head for this application, timing is everything, was used, very compe***ive, engine rule change and It was all done for me and this concept.
    Jet96, Deuces, James D and 8 others like this.
  20. Fordors
    Fordors
    No, look closely, the tubing is held to the cylinder head with banjo bolts and drains the head to the oil pan. There is a third bolt obscured by the steering box and probably one last one too.
  21. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Thanks Fordors. Care to shed any light on what looks to be a blow-off valve? Is there parts removed (turbo???)
  22. Fordors
    Fordors
    Just NE of the red arrow it looks like that’s a Roots blower with a single carb, probably bevel gear driven.
    Thor1 likes this.
  23. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Thanks. That truly IS an unusual engine.
  24. saltflats
    saltflats
    from Missouri
  25. Mark Wahlster
    Mark Wahlster
    How about a Hot Rod Willys 134L
    Jet96, Deuces, mkebaird and 5 others like this.
  26. Fordors
    Fordors
    Alden Sampson is seen with the 16 cylinder engine Frank Lockhart created from two 91 cu. in. Miller straight eights. Riley Brett used the engine in a 1929 Indy effort that DNF. Brett rebuilt that car and engine for the 1938 Sampson Special.
    lurker mick, Jet96, Deuces and 9 others like this.
  27. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    A stunning piece of pre-CNC machining.
  28. Fordors
    Fordors
    Early in this thread I posted a photo of this engine, but this one shows more detail. The Harry Miller built Gulf Oil effort was not only rear engine but also four wheel drive. Six cylinder and Roots blown Miller later added a second Winfield carburetor and an intercooler.
    lurker mick, Jet96, loudbang and 4 others like this.
  29. Fordors
    Fordors
    George Barringer is seen with the Gulf engine. Looking at it, like all of Miller’s designs I’m struck by the beauty that Miller turned out. Harry came up with the concepts and Leo Goossen his engineer/draftsman, and the pattern makers and machinists that completed the projects were truly artisans.
