Unusual engine photos
Discussion in 'Off Topic Hot Rods & Customs' started by William Thompson, Sep 28, 2018.
  1. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Thank you for that detailed explanation Ned Ludd.
    jimmy six and Ned Ludd like this.
  2. miguel.st
    miguel.st
    from germany
    Nothing to go racing but somehow unusual even when there are a lot fans still around here. Incredible sound you can hear from miles away from the 10lt 2-stroke glow head diesel
    https://m.youtube.com/shorts/GPMQ16ONGFE
    CE3C5FF5-11F6-4FEC-BAE5-954D4B2C8EB6.jpeg 72D99635-B924-4AC5-A403-04F6C9B6980E.jpeg
  3. AmishMike
    AmishMike
    ^^^. Very interesting, thanks for posting. Who be first to build a hot rod around Lanz engine: 10.3 liter ( about 628 ci ) single cylinder, 45 hp at 650 rpm that can run in reverse
    Deuces likes this.
  4. saltflats
    saltflats
    from Missouri
    warbird1, Okie Pete, Deuces and 3 others like this.
  5. Deuces
    Deuces
  6. Deuces
    Deuces
    The Trenton engine plant is still building Hemis today for the new cars and trucks... I have a friend that works there....
    motoklas, chevy57dude, Thor1 and 3 others like this.
  7. AmishMike
    AmishMike
    ^^^ explanation/name description of each would be nice
    Deuces likes this.
  8. j hansen
    j hansen
  9. saltflats
    saltflats
    from Missouri
    They using the front distributor just for primary ignition and the rear for secondary?
  10. Fordors
    Fordors
    I’ve always had a thing for just about any internal combustion engine, here’s a 1908 gasoline engine designed by William R. McKeen for a powered, p***enger rail car. Notice the long lever at the top, center of the photos, read the caption to learn it’s function :eek:
  11. jimmy six
    jimmy six
    Those look like Barnes heads ….but I don’t recognize the block!
    Deuces likes this.
  12. Deuces
    Deuces
    Could be an LA Mo power small block....
    seb fontana likes this.
  13. Fordors
    Fordors
    Weslake heads on the small block Mopar in the off topic Plymouth Colt of the Rod Shop team.
    jimmy six likes this.
  14. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Gurney Weslake heads. I had an almost identical set for a SBF, with a rare 4V intake. Weber carbs also bolted directly to the ports.
    rod1 and jimmy six like this.
  15. 270ci
    270ci
    Is that a slide valve fuel injection system on there?
  16. Fordors
    Fordors
    Yes, those are slide valve injectors. The heads were developed by Harry Weslake for the 1969 Plymouth Indy car program. The Plymouth Indy car/Formula 5000 effort only won one race.
    loudbang, Deuces, 270ci and 1 other person like this.
  17. jeepsterhemi
    jeepsterhemi
  18. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    I wonder if the point on the firewall tank was done "to improve aerodynamics"???
    Dig the right side tandem rubber.
    Thor1 and AmishMike like this.
  19. Jack E/NJ
    Jack E/NJ
    from NJ
    Looks like it might be a huge V4 slightly tilted for a better view out front.
  20. j hansen
    j hansen
  21. jeepsterhemi
    jeepsterhemi
  22. Deuces
    Deuces
  23. Jack E/NJ
    Jack E/NJ
    from NJ
  24. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    I see what looks like a V4 gas motor the the front. Maybe the starter motor? - yikes
  25. Acres
    Acres
    from Sweden
  26. T. Turtle
    T. Turtle
    Standard set up on many full size marine engines which are directly coupled to the propeller, nowadays servo ***isted of course.
  27. jeepsterhemi
    jeepsterhemi
    Flathead V8 built with 8 lawnmower engines...
  28. AmishMike
    AmishMike
    ^^^. Would love to see all the details how it was built/put together
  29. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    ...and what, if anything, was it used to power?
    AmishMike likes this.
