Technical Update: Fixed slow speed (5-15 mph) death wobble
Discussion in 'Traditional Hot Rods' started by banjorear, Aug 19, 2023.
  1. Boneyard51
    Boneyard51
    Yep, bad components can hide problems. Wide wheels and big tires make it worse. Also big tires are harder to balance and keep balanced. They can make a big problem out of a small problem.
    Most lift kits do have the things to keep the caster right or close to right. But that’s the thing….minor changes in castor can make big problems or solve big problems.
    Plus any straight axle , under the right conditions, could wobble! That is why the OEMs put stabilizers on four wheel drives from the factory!
    Bones
    Alton Stroope, bschwoeble and patsurf like this.
  2. 1971BB427
    1971BB427
    from Oregon
    If this was true then factories would have put them on any vehicle with a solid front axle. They put stabilizers on 4x4's because of the larger diameter and width of the front tires that exaggerate bump input to the steering wheel and stabilizers dampen that effect.
    Alton Stroope likes this.
  3. Alton Stroope
    Alton Stroope
    That's so true, the damper shock is not THE correct fix! They might "dampen" the wobble but not the correct fix. I have seen hundreds of death wobble cases as a front end man all my life & every car & truck rarely has the same fix for the problem. You need to start with a very thorough "shakedown" for the slightest slack in everything, it doesn't take much. check tires & wheels for runout & balance. Set caster at least 8 degrees+ & you should be there.
    Boneyard51 and bschwoeble like this.
