Projects UPDATE: Gasboy '30 sedan
Discussion in 'The Hokey Ass Message Board' started by Crusty Nut, Jun 24, 2008.
  1. Crusty Nut
    Crusty Nut
    I've been chugging away on this sedan. It won't be too much longer before it's time to take it apart for bodywork.
    I made up a little filler piece to fill the gap between the body and the deuce tank. I got to use my new shrinker/stretcher on it.
    Today I got the pedals mounted. I incoperated the pedal mount all the way across the cowl to turn the other side into a "glove shelf" instead of putting a glove box in the dash.
    With the dash in, the shelf is completely hidden.
  2. Crusty Nut
    Crusty Nut
    Here is a couple shots with the fenders and hood loosly mounted just for effect.
  3. Buzznut
    Buzznut
    So, the shelf is hidden...no door? You have to reach up and under? Looks like you've done some killer fabrication there - kudos!
    Can we see more pics of the green pickup?
  4. Old-Soul
    Old-Soul
    looking good man, that filler cleans up the back nicely
  5. Crusty Nut
    Crusty Nut
    Thanks. Yeah, just reach up. My green truck is pretty well do***ented here in HAMB land. Just look up some of my other threads.
  6. Rice n Beans Garage
    Rice n Beans Garage
  7. chaddilac
    chaddilac
    Dang that's a slick Cdan!! Nice job!
  8. Crusty Nut
    Crusty Nut
    I got a little more done. Mounted the steering column, please ignore the ***-ugly mullet master steering wheel.
    I took it all apart yesterday to finish up the frame work. Mock up phase is officially over. Too bad I hate body work.
  9. Slag Kustom
    Slag Kustom
    looks really nice and clean.
    you will want to add some more bracing to the pedal mounts. there is a lot of force on them.
    a good test is to put a pipe plug in the master with it full of fluid and have some one push on the pedal. if there is any flexing you need to brace it more.
  10. ironandsteele
    ironandsteele
    that's what i was thinking about the pedals too..
    nice work-it's coming along well.
