Ok without modyfying the block at all. Only the reduction chrysler starter will fit with the ****ter shield set up...........Aftermarket reduction starter wont fit bosch starter wont fit........... So the parts needed are 130 tooth flywheel smallblock ****ershield......You have to drill dowl holes And Genuine reduction starter Good luck and Happy HEMI DAYS
Don't recomend using bolts, even alloy sholder bolts, to try and keep the flywheel centered. The correct way is to center on the OD of the crank flange. Any other way can result is the bolts stretching and eventually failing.
Joe, g' day mate! hope all is well, how are the 7 dwarfs? Thanks again for the BBQ the time i stopped by your place last summer, i had a blast and it was awesome. you have a great family and a killer coupe I love the motor! take care and good luck with the '32 Phaeton project, how's that coming along? best wishes, CAB
G,day steve all is well just trying to get reach the potential of the coupe motor is out gearbox is being rebiult so it,s an oppertunity to trial a manual setup Your coupe looks like its getting the Xtream makover can not wait to see it finished stay cool catch ya later
