update on '27 RPU, fixin what aint broke
Discussion in 'The Hokey Ass Message Board' started by Paul, Nov 28, 2013.
  1. Paul
    Paul
    Editor
    she didn't sell this go'round
    so might as well fix what aint broke
    swapping the stock '36 axle for an old dropped and filled axle I had laying around
    just to give it a bit more rake..
    it's all fitted and rolling
    but waiting on a couple parts, perch bolts,
    destroyed one pressing them out
    and shock mounts,
    I had welded mounts to the old axle,
    'don't know if I want to weld on this one..
    jury's still out on that one..
    but it should be out and about again soon
  2. Hitchhiker
    Hitchhiker
    Such a awesome hot rod.
  3. rob-redm
    rob-redm
    Already a cool little hot rod. Should look great with this update. Great work Paul !
  4. Cowtown Speed Shop
    Cowtown Speed Shop
    from KC
  5. Paul
    Paul
    Editor
    more under the heading of fixing what aint broke..
    'been thinking of swapping out the sectioned Studebaker grill shell for a stock T shell lately
    when one turned up I tried it out.
    this shell was solid but beat up and the lower piece was missing
    perfect for what I had in mind.
    I separated the top panel from the surround, bashed them more or less straight
    and chopped it 3-3/4" in height and narrowed it 2" to fit my radiator
    and put the two pieces back together
    as a test run this did fine,
    I found and ordered a nice complete original shell
    and will repeat and refine the process shortly
    hard to see here in the shadows but, you get the idea
  6. Very cool hot rod. I liked the old grille shell, and the Ford one works great too.
  7. Paul
    Paul
    Editor
    the Studebaker shell was ok, and it worked when the car had the Sudebaker engine
    but looking at Ivo's and Kugie's and damn near every other car in a similar build style
    I like the T grill best.
    it would (will?) look better in color
  8. You mentioned at the start, that it didnt sell. Is it still for sale? Id put my wife to work on a street corner to buy it, if i had a wife :D
  9. Paul
    Paul
    Editor
    a bit of the look I'm after
    not sure about the top but,
    I do have the start of a set of original bows
    and it might be nice to sit in the shade once in a while
  10. alchemy
    alchemy
    Love everything about your car, except the headlights. Kugie's car confirms it, your headlights need to come forward about three or four inches. Maybe down one as well.
    Keep up the good work.
  11. Paul
    Paul
    Editor
    Yeah I was seeing the same thing, they are also quite a bit larger than what was common then.
    Mine are the BLC-682j's if I remember correctly,
    A smaller bucket might look better.
  12. pdunn10
    pdunn10
    any plans to shorten the wind shield? even with the top of the steering wheel would be a great look. It would give the car a little more attitude, the rest of the car has the low lean look and the glass seems to go against the flow.
  13. Malcolm
    Malcolm
    from Nebraska
    Great improvements, Paul -- such a cool, period perfect car!
    Malcolm
  14. SOHC427
    SOHC427
    Great looking ride. Very nice job.
    Eric
  15. Paul
    Paul
    Editor
    got a much better radiator shell in the mail the other day,
    you can see how much I shrunk the first one
    the first one had been hit sometime in the last 90 some years
    this one is nice and straight.
    I'll chop it up soon,
    should make things a bit easier
  16. Paul
    Paul
    Editor
    got the shell cut and welded back together,
    same 2" narrower but this time only 2-1/2" shorter to let the bottom hang down a bit more,
    shot some primer on it to better see where it needs more smoothing
    found a pair of NOS Dietz headlights,
    look like '60's era by the instructions
    they will go in place of the big BLC's
  17. 4 banger 4 life
    4 banger 4 life
    from ohio
    hell ya nice old hot rod... car is tuff......
  18. Paul
    Paul
    Editor
  19. Paul Windshield
    Paul Windshield
  20. Paul
    Paul
    Editor
    Thanks Paul
  21. I'm still confused as to why you would want to sell it.
    So cool!
  22. ochamsrasor
    ochamsrasor
    Paul,
    There will always be a home for this rod in Florida....................
  23. Baumi
    Baumi
    That´s a great little Hot Rod! I wouldn´t sell that:)
