this is a link to the photo album. -danny http://s226.photobucket.com/albums/dd313/hotrodpro/dans 32 pickup/
Amazing workmanship and design. This looks very functional for the pickup or any Deuce. Did you make all the pedals, brackets, etc? They look like Henry made them.
i did the design work and the drawings on my cad program,then had them waterjet cut.after all that i did all the finish work,and welding.somethings are faster to have cut than for me to machine on my machines. glad you like them. -danny
yea,it blew in through the roof vents.and rusted my junk.i'm about to take it all apart to do some finish work on the chassis.then paint the chassis,and put it back together.roundup here we come. -danny
practice,practice,practice.then repeat.the trick is to practice on expensive tubing,you will get better sooner. -danny
Have you test-fit that MSD box mount with the firewall in the car? Is there enough clearance between it and the underside of the cowl? Same goes for the fuse panel.
...was talking to your dad at Texas GG, and he told me to stop gushing over your work cause he said you was getting the bighead...
Hey Hot Rod Pro Are you offering the pedal setup for sale? If so, PM me on the cost and availability. I need one for the 46 PU! Looking at the pics.........Does it matter which side of the M/C is used for the clutch/brake? Looks like the side labelled "brake" is ran to the clutch. Or am I just seeing things?!?!?!?!
you are right.all you have to do is swap the pistons from side to side.the bore is the same.i will get a price together,and let you know. -danny
really cool. Those brackets are awesome. (I could tell it was going to mount MSD before I saw the box mounted!)
