Update on the making of a cylinder head
Discussion in 'The Hokey Ass Message Board' started by George Miller, Aug 10, 2010.
  1. George Miller
    George Miller
    from NC usa
    Been working on the ports and water jackets on both pieces. Still have more to do on the water jackets.
  2. MN Stumpjumper
    MN Stumpjumper
    Keep it up George!!
  3. second_floor_loft
    second_floor_loft
    George:
    Thanks for the update..Please keep the pics coming
    Paul
  4. What kind of Mill are you using? I have a Kearny Trecker 2H here and am getting ichy fingers just watching your progress.
  5. George Miller
    George Miller
    from NC usa
    ______________________________________________________________
    It was a old NC Moog that I got for s**** price. It was a hyd. machine in its first life, I changed it back to more or less a Bridgeport.
  6. oj
    oj
    You are doing this by hand? With just a digital readout? That is a piece of work. Keep us posted, thanks, oj
  7. '46SuperDeluxe
    '46SuperDeluxe
    from Clovis, CA
    I think that you said that this was going to be a 16 valve, overhead valve, head. Is this going to be similar to the old Peugeot style aftermarket head for a Model T with the cool forked rocker arms? Are they going to be pressure oiled or just a squirt before you make a run for it? I talked to a guy with a warmed over "T" and he said that there was a piece of oil soaked felt, under his rocker cover that he just added oil to periodically and that was sufficient to keep everything lubed up for a while. I'm told that was somewhat the procedure on the 4 cyl. OHV Chevs for 1928 back in the day. I'm sorry to be so impatient like a lot of these other guys, but I had considered grafting a '28 Chevy head to the Ford block similar to a video on YouTube called "Poor Mans Rajo"
  8. George Miller
    George Miller
    from NC usa
    _________________________________________________________________________
    No read out just use a dial indicator.
  9. George Miller
    George Miller
    from NC usa
    No it is going to have 8 valves. 2.020 intake and 1.600 exhaust
    No it is not copy of and ones head, and yes it will have pressure above the rockers, spray oiling.
    I did a 28 chev head once made a plate with a combustion chamber. The chev head is flat on the bottom. If I was you I would built a 100 hp flat head instead of the chev head, If you use the chev head you will need to put in big valves, the head is really restricted.
  10. PeteFromTexas
    PeteFromTexas
    This just gets better and better!!! I love it!
  11. George Miller
    George Miller
    from NC usa
    Did not get much done today, had to mow gr***.
    Machining for a water pump, and taking away extra metal around the water pump mount. I'm at 47 hours on the head. I was thinking 80 hours for making the head. Looks like it will be close. Now if you had every thing you needed in tooling and a CNC it would be a lot less hours.
  12. jbrittonjr
    jbrittonjr
  13. chaddilac
    chaddilac
    That's just so stinkin cool!!!
  14. Chuck Most
    Chuck Most
    from Saskatoon
    I can't even make a sandwich without epic fukkups, and you're making a head! That's cool!
  15. CH3NO2JAY
    CH3NO2JAY
    from Chicago
    Now that is what hotrods are all about...
  16. RichFox
    RichFox
    Boy that's a small table. 80 hours cutting on the head but how many planning. I know I could do the cutting. It's the planning that I am in awe of. I made a billet flathead and the planning gave me a headach for days. Everytime I try to think about what you are doing I get brain lock.
  17. haroldd1963
    haroldd1963
    from Peru, IL
  18. Abomination
    Abomination
  19. Not even a read out!,,,,You are a brave man, George, no "OOOPS" allowed. My machinist's hat is off to you>
  20. George Miller
    George Miller
    from NC usa
    When I first started machining we never heard of read out. We just counted turns and used numbers on the dials. The first read outs that I seen were in the late 60's
  21. A tip, to do this I hit the red quote ****on on the bottom right of the above reply. See how it gets set aside from my text?
  22. JC Sparks
    JC Sparks
    from Ohio
    Take a pic of your mill so we can see the entire machine. JC
  23. RichFox
    RichFox
    I remember the first set of Trav-A-Dials the company bought. I thought I had it made then. Still have Trav-A-Dials on my Bridgport
  24. When we make something I always get told you would have to have CNC to do that. (In fact i have even been told that on the HAMB ) To which I reply the first CNC was made on hand operated equipment. There is, as George is so capably proving, absolutley nothing that cannot be done by hand operated equipment with patience thought and care.
  25. RAY With
    RAY With
    One hell of a project to say the least.I hope you post the finished head so we can check it out. Just shows you how much talent there is on the HAMB
  26. A Chopped Coupe
    A Chopped Coupe
    Very, Very nice work....................I can't wait to how it performs once you get it finished.
  27. dudley32
    dudley32
    What sort of cam do you intend using..?
  28. 57JoeFoMoPar
    57JoeFoMoPar
    This is pretty bad *** man. This is the kind of billet we like!
  29. Weasel
    Weasel
    And you still get time to machine the head and shoot pix and post all this for the benefit of the HAMB community. Do you ever sleep??:p
