Projects update on the Model A Coupe
Discussion in 'The Hokey Ass Message Board' started by Paul, Sep 5, 2010.
  1. Paul
    Paul
    Editor
    will try to piece together the other side's tubes this weekend
    before welding all tubes to thier flanges and collectors
  2. Paul
    Paul
    Editor
    Performance Radiator called back with an estimate for the custom radiator this car needs...
    holy ****!
    about twice what the last all custom one I had them build cost..:eek:
  3. Malcolm
    Malcolm
    from Nebraska
    The dash and header both look great!!
    If you don't mind sharing, what steps did you go through to weld/grind/finish the header tubes so nicely?
    Malcolm
  4. Paul
    Paul
    Editor
    align the two tubes using whatever means you have
    fitment of course has to be near perfect
    tack with mig
    weld with tig
    carefully grind down weld to very near parent metal
    hand file to flush
    medium grit paper disc on 4" grinder to clean the file marks
    DA with medium grit, I think I used 180?
    and finally hand sand to take those marks out
    it actually goes faster than it sounds
    again biggest part is getting the pieces to fit nice to begin with
    I'll try to take more pictures on the second set
  5. Malcolm
    Malcolm
    from Nebraska
    Thank you, Paul!
  6. shane85
    shane85
  7. Paul
    Paul
    Editor
    thanks, looks like you have pretty cool car yourself
    I very nearly went with a 4-71 blown small block in mine too
    but when the parts came together to put an Olds in it I had no choice
  8. Paul
    Paul
    Editor
    on to the second side,
    clamped a short length of small channel in the vice
    layed two pieces to be joined in it and tacked them together in three places
    welded each tube up
    grind and file
    hit them with the little disc sander
  9. Paul
    Paul
    Editor
    followed by the DA sander
    tape,clamp and prop the tubes in place
    tack them to the sarter tubes and tack the ends together
    compare to the first side
  10. Paul
    Paul
    Editor
    tomorrow I can attack the collectors and get it all welded up
  11. n847
    n847
    Those headers are *****in! Are you going to run a block off plate and full exhaust or are you gonna go balls out?
  12. Paul
    Paul
    Editor
    'going to make some block off plates and outlet drops to run the exhaust under the car, through mufflers out the back... I think :)
  13. Malcolm
    Malcolm
    from Nebraska
    Thanks for the step-by-step, Paul. Much appreciated!
  14. 41 Dave
    41 Dave
    Paul, Your "A" is going to be one mean "A" Coupe ! I have a '31 "A" Coupe with a '57 Ford Marine Y-Block. It is adapted to a '46 Ford truck trans and the rear is a '41 Ford car. Car is mostly figured out but needs finishing. Will be building a stand alone water pump for cooling. Hope my "A" is 1/2 as cool as yours.
    Dave
  15. Paul
    Paul
    Editor
    sounds pretty cool to me,
    makes me think of the pink? one Marshall built a little while ago
    I really like the way the Y blocks look
    somebody once said they go pretty good too;)
  16. HOTRODPRIMER
    HOTRODPRIMER
    Paul,,,Beautiful work and attention to detail! HRP
  17. Paul
    Paul
    Editor
    welded the primaries to the starter tubes,
    pinched the tubes together where they meet inside the collector
    welded them together and about an inch or so up the tubes
    tacked the collector in place to check alignment
    back to the bench to weld the collector on solid
    then bolt back on one last time
    that's as far as I'll take this side for now,
    stopped to take the turkey out of the oven
    start the cranberry sauce
    then it's back out to the shop to put the other collector on
  18. Paul
    Paul
    Editor
    and second side done..
    well, as done as the first anyway
  19. rob-redm
    rob-redm
    Looking great Paul ! can't wait to hear that blown Olds run ! Nice work
  20. 41 Dave
    41 Dave
    Paul, I am also building a '41 Fordor with a Y-Block. Hope to have it all dolled out with T-Bird valve covers and 3 carb intake. Hope to be able to make it a Kustom. Chopped 2 inches, sectioned 2 inches and channelled 2 inches. Just got to do some wheeling and dealing.
    Merry Christmas to you and your family.
    Dave:eek:
  21. Paul
    Paul
    Editor
    I've only heard it on the test stand through mufflers
    and that was way too long ago
    I'm sure it will sound a bit different now
  22. Jeff Norwell
    Jeff Norwell
    MODERATOR
  23. Speedy Canuck
    Speedy Canuck
    Looking really slick Paul!
    Will there be video when things get fired up?
  24. Paul
    Paul
    Editor
    The picture you posted of your pickup in one of the header picture threads, meaty beaty big and bouncy, was an inspiration
    Count on it.
  25. CGkidd
    CGkidd
    Paul those look *****in...
  26. Paul
    Paul
    Editor
    picked up the radiator from the shop yesterday
    I had them build it without brackets so I could not only save a few bucks but I wanted to make sure to get them so they fit the way I want them to.
    started on that today,
    bent up a strap to go under the bottom tank
    tacked the upper shell brackets in place
    and got a plan for the lower brackets.
    but I may need to modify the cross member to get the whole thing a bit lower..
    Kreepea_1 likes this.
  27. shane85
    shane85
    Killer it looks super mean!!!
  28. Paul
    Paul
    Editor
    took the week between Christmas and New Years off,
    between chores I did manage to spend some time on the Coupe
    in an earlier mock-up I had tunneled a small block Chevy into the firewall,
    now that needed to be fixed.
    I found a crusty but solid donor firewall somewhere in the past
    figured it would be just as easy to patch the original as replace the whole thing
    so I did a rough layout of the patch needed
    and cut it with the trusty little grinder with cut off wheels
    clamped it behind the original and marked it for t*******
    and welded the lower half in,
    I intended to cut the center out for magneto clearance
    but left it in one piece to help with initial patch alignment
    when the sides were welded in solid enough I cut the center section out
  29. Paul
    Paul
    Editor
    bent up a recess out of similar gauge steel
    tacked it in and trimmed it a bit
    pounded out a bit of a dome to fill the top of the recess
    and welded that in
    fit the remaining patches using new steel
    worked it into shape with hammer and dolly
    and stripped the paint and rust
    while the tank was off I cut the top free
    and set the body back on the ch***is
    the engine just clears the remaining firewall,
    plenty of room for the plug wires
    and just enough room to pull the magneto
    slowly coming together
    that's all for now folks!
  30. VoodooTwin
    VoodooTwin
    from Noo Yawk
    Lookin awesome.
