Updated HAMBANDY build list...Aug22
Discussion in 'The Hokey Ass Message Board' started by movingviolation, Aug 22, 2007.
  1. Casey
    Casey
    did this ever make it home ?
  2. GrantH
    GrantH
    any chance cash for miscleanious bolts would be needed? I honestly don't have ****, but hopefully I can send atleast 10 or 15 in for the build....
  3. Hackerbilt
    Hackerbilt
    Come on Leon...put up a post on what has made it/what hasn't! ;)
  4. Lobucrod
    Lobucrod
    Alliance Vendor
    from Texas
    PM me an address and a phone # for shipping purposes only and I'll get it on the way.
  5. movingviolation
    movingviolation
    The parts that made it to date.........i will check the stash and see if there is anything i missed on this list later today
    Intake and carbs
    Harness and lenses
    Headlites steering and wheel
    Grill shell
    King pins
    Sweep tach
    Spring perch
    Front spring
    Carb rebuild and set up
    Mufflers
    Fuel block
    Fuel regulator and gaskets
    Shockmounts
    All the parts from Joplin are intransit and will update when they arrive.
    I understand the shipping can vary from place to place, so as it gets here i will update the list.
    Leon
  6. movingviolation
    movingviolation
    You have pm
    Thanks alot
    Leon
  7. movingviolation
    movingviolation
    Well folks there are still a few pieces that are still to arrive. If there is any shipping problems please let me know and i will get it taken care of from my end.
    Andy is home from his 2 hospital visits in the Unite States and is now eager to try his hand at hot rod building.
    To all who have sent parts todate................Thank You very much. You Are instrumental in Andys success
    Thank You so much
    Leon House
  8. 31whitey
    31whitey
    hey man
    what are you guys still looking for?
  9. Man this is fantastic. Yup hot rodders are the best people there are, I don't have anything to send (Postage would be a killer anyway) but I would like to help out in some way.
    Would love to see some pics of the build, has anyone thought of starting a HAMBAndy web site for the build? Maybe we could drum up $$ from a wider audience?
  10. atch
    atch
    has the stash from joplin arrived?
  11. bigken
    bigken
    Ditto - Leon, can you create a list of items still needed?
    Thanks man.:D
  12. movingviolation
    movingviolation
    Hey everyone,
    This is a list of parts that we still are on the lookout for...........I will douple check the parts that are here to make sure we dont look for parts twice.
    Shackles to mount front spring
    front flex lines
    Tie rods for drag link
    gear box parts??
    drive shaft parts (yoke to gearbox)??
    transmission mount??
    Shackles to mount rear spring
    Rear spring mounting brackets
    rear shocks
    Rear shock mounts
    gas tank
    master cylinder
    hand brake..............still waiting to recieve
    brake fittings
    lug nuts
    9 inch ford rear end parts (drums, brakes etc)
    rear radius rods or ladder bars
    Flattie parts
    oil filter
    plugs
    Radiator hoses
    Header flange gaskets
    distributor
    intake gaskets
    clutch/pressure plate
    fuel line
    Dizzy for the flat head.
    Rad overflow tank...
    Heads
    Beehive oil filter
    Insert for 32 shell
    Switches and ignition with keys
    Headlight stands
    Thanks
    Leon House
  13. jambottle
    jambottle
    hi leon;
    let me know if you still need lugnuts.i`ve got a chrome set here i can send to the rock. how is our boy doing?
    regards chris
  14. movingviolation
    movingviolation
    Hey Chris, we are still looking for studs..........but lug nuts wouldbe sweet!
    Andy is doing well, much tougher than i would be for sure....He is doing Christmas shopping (or has plans to) and is posting here. All i know is i'd still be licking my wounds!!!
    Take care Chris
    Leon
  15. CURIOUS RASH
    CURIOUS RASH
    Classified's Moderator
    What kind of studs are you looking for?
  16. movingviolation
    movingviolation
    Ill get fitzee to post them or Chris can tell you for sure....
    It will be day before i get back home to see fitz............
  17. jambottle
    jambottle
    the studs are to go thru the buick drums and thru the old ford hubs..the studs that were listed for this on the buick drum conversion thread do not have serrations long enough to reach the steel hubs.(they just barely reach the steel(iron) old ford hubs.i think this may be unsafe because it does not anchor the drums securly to the hubs and the studs may turn in the softer aluminum ,when tighting or loosing the wheels.maybe some on here has a# for studs with longer srerrations on the shaft of the stud.this may be as clear as mud but if you have questions let me know.
    chris
  18. jambottle
    jambottle
    i bought a set of DORMAN #610-132 & NAPA #641-1145 as recomended in the hamb teck thread about adapting buick al. drums to old ford front hubs.on both sets of studs, the serrations are to short to reach the ford hubs.one fix would be to drill and tap the drum and hub from the back and bolt them togather.anyone?
    chris
  19. jambottle
    jambottle
    here is a picture of the studs we have.the stud in the middle has the correct stirrations to be driven into the 5/8 inch hole in the ford hub and buick al.drum.but the stirrations are not long enough to reach the ford hub.the stud on the left also takes the old ford lug nut (1/2-20),
    and the stirrations are the right length but it is too small in diameter at the stirrations to lock correctly in the 5/8 hole.there must be a commercial stud that will lock the drums on andy`s car ,so he will not have to worry about problems in the future.total length is 1 3/4 inches,
    5/8 inch stirration length+ or- a little.anybody have a stud selection guide for some part #`s.
  20. movingviolation
    movingviolation
    I know that time is ticking away on Andys build and Fitzee and Hacker bill are hot on the build..........so for those who have not sent their donations please contact me and i will arrange shipping.....no problem.
    We are reaching a time crunch now and the snow is going to melt soon.........and i wanna see Andy pushing the pedal down on this ride.
    Leon
  21. movingviolation
    movingviolation
    BTT so we can get'r done for Andy.
    We will soon spending the money that was raised to get Andy to Joplin to buy the parts that have not arrived or have not been dontated.
    I have all the info for the adaptor and spoke with the supplier...so i will purchase this on monday. Adam at autowonderland will be ordering other parts for me.....grill insert for 32 shell and shifter.
    Once again, i will cover shipping to get the stuff we need that has not arrived.
    Leon
  22. Conder
    Conder
    Hey, did Andy ever get the drawing I sent? It went out a while ago...GREAT THREAD AND A GREAT PROJECT!!! Go man GO!!!!
  23. movingviolation
    movingviolation
    I believe he did, but pm him...he is very active on the board. When they cam back from the USA all packages went directly to him. Sooooo although i have seen a drawing, i'd pm him to be 100% sure.
    Thanks so much
    Leon
  24. movingviolation
    movingviolation
    I'll get Andy to update the goodies he has home.............
  25. N312RB
    N312RB
    from Burlington
