Technical Updating nwc T-5 install
Discussion in 'The Hokey Ass Message Board' started by nutter_street_rodder, Jul 21, 2024.
  1. nutter_street_rodder
    from Nevis MN
    I just swapped a different nwc T-5 in my '32 Ford. Since all was working fine I just swapped transmission only. Had the first one in 10 years. The deeper gears really helped drive ability.
    Then the problems began.... drove to fill gas tank up and when returning home a weird howling noise off and on began, Seemed to be related to clutch movement. Decided it must be the throw out bearing, so out came engine and transmission again.
    After removing transmission, I noticed the starter drive was engaged. Turns out the pin that rides on the starter shaft was bad, causing drive gear to slide back and forth on shaft worm freely. OK, easy fix from stock pile of parts.
    But I bought a new throw out bearing ***embly and spring & also decided to eliminate the "Speedy Bill" pilot bushing adapter, so I have the Offenhauser Ford to S-10 roller pilot bearing in hand. The old Ford one isn't easily coming out. I have a Fidenza aluminum flywheel. Is the bearing inserted into the flywheel or crankshaft? I'm thinking the '40 221 engines went into flywheels?? If so, guessing that means pulling pan to get flywheel off?
    Is there anything thats .668" diameter to try the old grease and driver trick to remove it?
  2. gimpyshotrods
    gimpyshotrods
    Find a 5/8" bolt that is not threaded all the way up. Cut the threaded portion off.
    Use that as the driver for the grease trick.
    (0.668 - 0.625)/2 = 0.0215" clearance around the bolt. That should be tight enough for the grease trick to work.
  3. krylon32
    krylon32
    from Nebraska
    Bushing or bearing they go in the flywheel.
  4. GordonC
    GordonC
    Just watched a video yesterday of a guy using white bread to drive the pilot bearing out of a 428 Ford engine. He used the clutch alignment tool to drive the bread in. Said it cleans up easier than grease. I am sure that could be used on most.
    Just.dale likes this.
  5. chicken
    chicken
    from Kansas
    Although never tried it, I've heard the same and it makes sense.
  6. nutter_street_rodder
    from Nevis MN
    Tried a rental tool pilot remover with no luck.
    Saw online to try wrapping a bolt with electrical tape to get a snug fit for grease trick. It worked!
    The flathead pilot bearings do fit into the flywheel!
    Thanks all!
    gimpyshotrods and winduptoy like this.
