Upholstery, a beginners journy
Discussion in 'The Hokey Ass Message Board' started by Thommyknocker, Nov 25, 2012.
  1. jakesbackyard
    jakesbackyard
    from ND
    That candy striped seat looked the same. I've got lots of foam s****s and carved wedges out of s****s to rough fill the divets. Then 1/2" sew foam on the fabric should hide it all.
  2. Thommyknocker
    Thommyknocker
    from Colorado
    Man everything always shows up at once.
    Sewing machine parts and the rest of my materials all showed up today
    I've been playing with the sewing machine and I've decided that its to fast for me.
    So I ordered parts and put another jack shaft in it to slow it down :cool:
    Before and after pics
  3. BrerHair
    BrerHair
    OK, I'm dumber than I look. You fellas are starting to lose me with this scrim foam/pleat talk. Pics please, when you can. Thanks.
    Cool move on the machine Thommy, love it.
  4. jakesbackyard
    jakesbackyard
    from ND
    Scrim foam is 1/2 or 1/4 inch foam with a backing fabric already attached as a backing on one side used for sewing pleated (quilted) panels.
  5. Thommyknocker
    Thommyknocker
    from Colorado
    Brer,
    Ask and ye shall receive!
    I "cheated" and bought pre-pleated material. They used 1/2 sew foam and ran it through a sewing machine to make the pleats, see the green material pic.
    The next one is 1/4" sew foam, just thinner.
    I'm doing computer maintanence tonight, so I might as well add some pics.:D
  6. Binger
    Binger
    from wyoming
    Thommy have you ever been to Colorado auto trim? i believe its on Meade street in denver. I will have to look for the exact address. they have lots of old stock materials and so on. Also i have used B&D on broadway in denver also.
  7. Thommyknocker
    Thommyknocker
    from Colorado
    Nope Binger,
    Materials are already here. No turning back now :rolleyes:
    I'm really liking the gear reduction on the machine. very controllable and plenty of power.
    Victory is mine (for now)
    I got my first real piece finished and installed. The p***engers kick panel.
    I tried a 3/8" binding on the carpet piece, but it was tough to fold the material and hit both pieces.
    1/2" aint to bad, and I actually got it straight LOL
  8. 38FLATTIE
    38FLATTIE
    from Colorado
    Wow! Looking good!
  9. Binger
    Binger
    from wyoming
    Looking great! I am an amateur at best with upholstery and am glad to have found this thread. Its nice to see some of the "old school" that are willing to help out with years of experience. I am about ready to start an OT '68 chev truck and this gives me inspiration! I only hope I can do as well as you have so far.
  10. BrerHair
    BrerHair
    Thanks guys for the lesson. Looking good!
  11. Thommyknocker
    Thommyknocker
    from Colorado
    Thanks guys :eek:
    the door panels are coming along! I just finished the p***engers side.
  12. 56premiere
    56premiere
    Looking good Thommy. Simple & clean. Keep going. Jack
  13. harley jim
    harley jim
    looking good thommy,
  14. Thommyknocker
    Thommyknocker
    from Colorado
    Thanks for the encouragement! :beer:
    I got a bench seat rebuild kit, so I've started working on that.
    Question: would you use the dacron batting on top of the foam, even with the pleated (1/2" sew foam) material?
    Is there even such a thing as to much padding? LOL
    The bottom of the seat is pictured first. I think I can do this one no problem.
    The backrest is the next picture. I will probably have to get more batting to smooth/fill the top of the backrest.
  15. 56premiere
    56premiere
    I personally would not use it. But there are many that do. It can help a novice to fill voids etc. It tends to ball up due to the way its made. Thick and thin ,I don't like the looks esp. under plain parts. Cotton was a better product in my opinion. I still use cotton on some , will not use Dacron ..Jack
  16. jakesbackyard
    jakesbackyard
    from ND
    Dacron is used a lot in furniture uph. Not much in automotive. It won't hurt to use it though. Put it on top of the foam. Lightly glued down to the foam would be a good idea so it can't shift around with use. Never know how that rear seat will get used when it's all pretty!:)
  17. pearl31
    pearl31
    I have a clean up question.What would you use on black naugahide to clean up what might be traces of glue? Its in the left shoulder area of my model A. I've tried wd40 and goof-off with little results.
    Pearl
  18. beachbum jim
    beachbum jim
    from Loris, SC
    Mineral spirits.
  19. Thommyknocker
    Thommyknocker
    from Colorado
    Cool, thanks guys. I think I'll try to use it.
    DOH! best laid plans......
    It looks like my material is not wide enough to cover the back seat in 1 piece.
    I can stretch it out a bit wider, but the pleats go kinda flat.
    hmmm, would I better off with a piece sewn in the middle, or 2 smaller ones on the sides to make it wider?
    I was originally thinking of having the entire seating area green, to better match Jake's simplified candy stripe example.
    Also, when making the pattern, where would you plan for the skirts to meet the face (how "tight" would the face be) on the foam.
    Thanks for all the help.
  20. Thommyknocker
    Thommyknocker
    from Colorado
    I'm about to start on the back seat.
    I think I've figured out what I want to do to make the green material wider.
    I'm going to add a strip of unpleated green to the outside. It would blend better into the side panels IMHO
    I do have a few questions for the experts
    1) how "tight" do you make the pattern? Like how much smaller would you make the face compared to the foam on the frame, 1/4" or 1/2" per side?
    2) Can I hog ring the cover directly to the frame, or should I try to put listing wires along the bottom? I've seen both. <!-- / message --><!-- sig -->
  21. Thommyknocker
    Thommyknocker
    from Colorado
    Oh, and here are the door panels installed. They actually line up!
  22. ZZ-IRON
    ZZ-IRON
    from Minnesota
    the panels are lookin good
  23. K13
    K13
    Looks good. BeachbumJim told me to make the seat tops the same size as the foam then sew the facings to that so you will lose 1/2" for seam allowance and that should make them pretty tight.
  24. jakesbackyard
    jakesbackyard
    from ND
    Panels look nice. K13 is correct with allowances. I would use listings and wire on the bottom edges. Looks professional and keeps every thing even.
  25. 56premiere
    56premiere
    When you first ask about extending the cover I wrote a pretty detailed summary, then punched post and it disappeared:D I just didn't have the umph to write it again. Think you got it figured tho. Jack
  26. Thommyknocker
    Thommyknocker
    from Colorado
    Don't you hate that Jack?
    I think I've got it, thanks for the clarification guys!
  27. beachbum jim
    beachbum jim
    from Loris, SC
    Keep up the good work Thommy!!!! Looking Great!
  28. Thommyknocker
    Thommyknocker
    from Colorado
    Thanks,
    But I've run into a bit of a problem.
    When I cut the pre pleated material, the s***ching comes apart.
    How can I secure the seams?
  29. 56premiere
    56premiere
    Maybe mark your edges and sew across the end of the threads. Hope they aren't chain s***ch or you might end up with plain material!:D I have used a tiny touch of super glue on problem s***ches , but test it on a s****, Some cloths smoke like crazy. Or a dab of contact cement or tie the thread ends or? Having fun yet Thommy? Problems arise no matter how much experience you have.. Jack
  30. beachbum jim
    beachbum jim
    from Loris, SC
    Welcome to the wonderful world of T*******!!!
