upholstery sewing machines
Discussion in 'The Hokey Ass Message Board' started by tedley, Sep 27, 2012.
  1. Kerrynzl
    Kerrynzl
    I've been sewing since 1976, and have never come close to a "needle in the finger"
    The Walking Foot gives you a "Warning Shot" ,and the brakes on these machines will stop within 10 degrees of rotation.
    The best tip I can give anyone on the Hamb is.
    HOLD the fabric as if you are using a Hacksaw [ one hand behind the needle feed ]
    You can manually hold the correct tension on the fabric and ***ist it through the machine.
    This is also good when sewing a fabric cut on the "Bias" [diagonal]
    If you sewing a really stretchy fabric, tape it with "cellotape" to prevent stretching [ rip the perforated tape off afterwards ]
    Cellotape is your "friend"
  2. 56premiere
    56premiere
    I have said before,pfaff is my choice for the last 45 years.tried others,just didn't like them.ive probably sewn 100000 miles,1/8 inch at a time.when you look at an ad that says commecial,walking foot,sometimes they are only machines with a carrying case.that is not what you need,if it don't have a stand,you won't be happy.my machines are pfaff 145 h4,1245 ,145h3. I modified the lift on my h4 so it proides 1"of clearance,it will sew over whatever gets in its way.,and quickly[no sloed down drive.good luck with your search,expect to pay maybe 500,hope for better price.
  3. Bighead
    Bighead
    I put a small pulley on the motor to slow my down, works better for me as I just leaning. my input.
  4. Canuck
    Canuck
    "Pffaf 145 he" for $750 in Kijiji right now in Winkler but not for $2-300 or I can ***ure you it would be in my ba*****t right now. I've been watching too.
    Like the idea of gearing a machine down but may not be easy on all machines. Had a Singer tailor machine that had the flywheel mounted on the motor. Wife would not use the machine when that 1/2 HP motor fired up and the only way to slow the sewing down was slip the clutch.
    Canuck
  5. kscarguy
    kscarguy
    I have a Juki LU-562 and it works great. After I bought it for $300, I sent it out to be clean and adjusted - $100. IMO that was well worth the money. It is a walking foot machine and can handle just about anything I shove under the needle. Even though I put a smaller pulley on it, it is still tricky to make clean sharp curves. I am thinking of swapping to the newer motor that can be slowed down. To get serious, I also need to mount a table around it. The factory table is so small that as the pieces get bigger they get harder to handle.
  6. bill512004
    bill512004
    tell me more about your sewing machine and where are you located what state
  7. bill512004
    bill512004
    price???????
  8. George G
    George G
    I picked up 2 of these 211 G 155 singers cheap and used one for parts.
    Found a table with a clutch drive so we (my wife) should be good to go.
    Any comments if this model will handle heavy stuff? Is a piping foot available for it? ImageUploadedByTJJ1359268586.556620.jpg ImageUploadedByTJJ1359268599.533580.jpg ImageUploadedByTJJ1359268610.984895.jpg
  9. txturbo
    txturbo
    My setup......
  10. 56premiere
    56premiere
    That singer should do fine, but I don't think it has reverse. There should be any thing available as far as feet. Check sewingpartsonline,the bay,or just search 211 parts. Good luck Jack
  11. George G
    George G
    Correct. There is no reverse. Thanks.
  12. stanlow69
    stanlow69
    There should be a swing arm mounted to the motor which engages the machine. This should have a wingnut with a spring on it. Just tighten the wingnut down. This is the quickest way to slow down a speedy machine. Then proceed to a smaller pulley.
