Technical Upper radiator hose for tri power 32 walker radiator
Discussion in 'Traditional Hot Rods' started by jcwalker215, Nov 29, 2019.
  1. jcwalker215
    jcwalker215
    from Horsham PA
    Does anyone have a part number for a upper radiator hose that will work on a 32 ford walker radiator with a tri power set up on a small block chevy. I tryed a napa 7029 but that doesn't work because of the offset to the driver's side of the intake manifold.
    Sent from my SM-G930V using The H.A.M.B. mobile app
  2. Chicster
    Chicster
    Just get a thermostat housing that works.
    lothiandon1940 likes this.
  3. Fortunateson
    Fortunateson
    I never knew there was tri-power radiators. All my vehichles use the standard rads so I guess they are uni-power? LOL
    LOU WELLS likes this.
  4. jcwalker215
    jcwalker215
    from Horsham PA
    Never really realized how many different angles you could get from a chevy thermostat housing. Any suggestions on the angle?
  5. Chicster
    Chicster
    You can get one that is straight up.
  6. jcwalker215
    jcwalker215
    from Horsham PA
    I will look into that. It would have to be pretty short to clear the front carburetor.
  7. 325w
    325w
    Tri 5 v8 correct tstat housing
  8. evintho
    evintho
    Go down to your local Autozone/O'Reilly's/etc and get a length of heater duct hose in the correct size for the thermostat housing and rad inlet. Bend it to fit your configuration, then go back and match it up with a radiator hose. Easy, peasy!
    lothiandon1940 and deathrowdave like this.
  9. jcwalker215
    jcwalker215
    from Horsham PA
    Thanks for all the feed back. Any more is greatly appreciated.
  10. Dak Rat
    Dak Rat
    from NoDak
    A thermostat housing from a 1980 chevy citation V6 goes straight up and fits the V8 manifolds. Discontinued part number but might be available after market. Have one on my '32 with walker radiator.
