Upper Steering column Bearing Assembly
Discussion in 'The Hokey Ass Message Board' started by Butch1, Sep 16, 2024.
  1. Butch1
    Butch1
    from Upstate NY
    I'm looking for an Upper Steering column Bearing ***embly for a 1954 Ford crestline. I can't seem to find ny on line. Bearing is missing -no idea what part number is. Has anyone installed an aftermarket steering column in this model and if so, what length did you use? I'm trrgusenying to mate it up to a Borgsen power steering gear.
    Thanks for any help,
    Bumstead1
  2. Moriarity
    Moriarity
    SUPER MODERATOR
    moving this to the main board, antiquated is for non automotive stuff
  3. i7083
    i7083
    Can you get measurements from where it goes? ID, OD, thickness. Then a bearing listing might get you there. Or something that might work with some mods to the column.
  4. Russ B
    Russ B
    Delrin is a material that can be used to replace a low pressure bearing/bushing. I used it as an upper bushing for the steering column I built for my 29 cabriolet. It can be bought in many forms. I got a solid tube section that only needed a hole in the center and cutting the drilled piece to the length needed.
  5. squirrel
  6. Fat47
    Fat47
    Call Shoebox Central.
  7. pprather
    pprather
  8. squirrel
    But that part is just the sleeve, not the bearing itself
