Technical Upside Down Mallory Distributor
Discussion in 'Traditional Hot Rods' started by 29ron, May 16, 2022.
  1. 29ron
    29ron
    I have a 2 bolt Mallory distributor for my 48' 59ab Flathead. When I intall the distributor the coil wire portion of the cap hits the lower pulley. Has anybody turned the cap around 180 degrees and used the original firing order to make this work properly?
  2. 42merc
    42merc
    Looks like you are trying to bolt the Mallory on upside down.
    Pist-n-Broke likes this.
  3. alchemy
    alchemy
    The vacuum brake should be upwards. The coil wire port should be upwards. There should be a tang on the distributor body that prevents the cap from being put on upside down.
  4. 29ron
    29ron
    Apparently you can put the distributor on both ways. Thank you for your help.
    42merc likes this.
  5. alchemy
    alchemy
    The vac port won't match the front cover if upside down.
