Upside down ??
Discussion in 'The Hokey Ass Message Board' started by V4F, May 7, 2012.
  1. V4F
    V4F
    from middle ca.
    for the rebuilders . when your upside down (as in changing pan gaskets in the car) , what type of stuff do you use to hold the pan gaskets to the block while your trying to put the pan up ?? i cant glue them to the pan as the pan rails have to go under the end gaskets . thanks for any info ........... steve
  2. bgaro
    bgaro
    rtv,formagasket, silicone
  3. Ados , F2 . Glue em to the block
  4. WornOutOldMan
    WornOutOldMan
    from So Cal
  5. V4F
    V4F
    from middle ca.
    Ados , F2 . .... ??? what is it ??
    tried silicone but messy & doesnt set fast enuff .
    there is a permatex item (cant remember) that works perfect .
  6. n847
    n847
    RTV...put it on thin, and let it set up a little bit. I've never had a problem with it!
  7. V4F
    V4F
    from middle ca.
    does the "indian head" set up quick ?
  8. Blue One
    Blue One
    from Alberta
    Silicone has a bad habit of making any kind of gasket squirt out from where it should be.
  9. It's a contact adhesive , get the aerosol one not the tube type .
    Edit : I just did a google and it appears it may be a New Zealand only brand . Go see an Upholstery buddy , they will use spray on Contact glue . Use it sparingly - just a thin coat on gasket and block , let it "tack up" and then position gaskets . Leave the pan side clean/dry .
  10. V4F
    V4F
    from middle ca.
    i have used silicone since it came out . good stuff when used correctly . but it lets the gasket fall unless you wait awhile . im not to good at waiting .......... thanks
  11. 302GMC
    302GMC
    from Idaho
    3M yellow weatherstrip cement in a very fine line. If you can see it when the part is installed, you used too much.
  12. V4F
    V4F
    from middle ca.
    4T6 , thank you . if your avatar is your car , im jealous !!
  13. Chris Stapley
    Chris Stapley
    Permatex makes a product called " the right stuff" and they are not kidding when they named it... Comes in an aerosol or tube for the caulking gun.
  14. Don's Hot Rods
    Don's Hot Rods
    from florida
    I saved four of those blue plastic studs that come in some FelPro gasket sets and use them whenever I am putting on a pan gasket. They are 5/16 course thread and fit most blocks. You simply screw them in on four corners of the block, slide the gasket over, and then the pan, and put some bolts in the remaining holes. After that you remove the plastic studs and put in the four remaining bolts.
    I've also become a big fan of the blue reusable rubber pan gaskets. They take no sealant and I have never had a drop of oil seep out since I have begun using them. They also eliminate the need to s****e old sealant off if you drop the pan in the future.
    Here is the gasket type I am currently using, and those four alignment studs make it a cinch to install the pan and gasket while standing on your head. They also feature metal rings around each bolt hole so you can't overtorque the pan bolts.
    Don
  15. porkshop
    porkshop
    from Clovis Ca
    I use 3M heavy duty spray addhisive, on clean dry surface..Works like a champ....
  16. bobss396
    bobss396
    Yup, aka Gorilla Snot. It doesn't take much at all to retain the gasket, I've used it for years.
    Bob
  17. fossilfish
    fossilfish
    from Texas
    It can be tough to get off later but a thin layer of 3M trim adheisive(monkey snot) does a good job. Put a thin bead on both surfaces let them sit for a few minutes before putting the gasket on the engine and the gasket will stick. Silly cone works too but you only need a very thin layer and it take a bit longer to set up...but it is usually easier to clean off. Like the rest of the guys point out that if you use too much silly cone and you don't let it set up, the gasket can slide around....I have also used and prefer it when I am building an engine on a stand permatex brush on aircraft sealant. The set up time on it takes a while before a gasket will stick to the bottom of the engine, if you are in hurry don't use it ...your results may vary.
  18. ArchangelKustom
    ArchangelKustom
    from NR/OH
    Permatex "Hi-Tack" - sticky red sealant, brushes on and tacks up quickly. Available in most parts stores. Impervious to gas and oil.
  19. V4F
    V4F
    from middle ca.
    Permatex "Hi-Tack" - sticky red sealant . what is the part # ??
  20. WornOutOldMan
    WornOutOldMan
    from So Cal
    Very tacky in about 5 minutes. Enough time to get your gasket in place. "right stuff" was also mentioned. Works awesome instead of a gasket. It was and is used by many manufacturers as OEM.
    Indian Head = Old School OEM
    Right Stuff = New School OEM
  21. Thanks , not mine - I did a frame up rebuild on it for the owner who is a good friend. Runs Desoto Hemi , 4 speed Toploader and early ford rear . More pics in my albums .
    The 3m Contact / trim adhesive mentioned in posts below sounds the same as
    the F2 Ados .
  22. V4F
    V4F
    from middle ca.
    apparently they do not sell Ados , F2 to the usa ...............
  23. gas pumper
    gas pumper
    Gaskachinch(SP) used t be used as a shoe maker's cement. Now one of the cam makers sells it as a gasket glue. Really good stuff for holding stuff in place. And the contact cement for Formica works very well, too.
  24. 1949*john
    1949*john
    3m general trim adhesive , clean the block with lac. thinner .
  25. shoprat
    shoprat
    from Orange, CA
    Just did the pan in my 57. Permatex that stays just sticky works well. I don't remember what it's called, ask the parts house. Been on the market for years.
  26. austinhunt
    austinhunt
    YES, I'm no engine expert but have some experience eating glue.
    Also to everyone that said rtv.... Permatex "Right Stuff" is the way to go. RTV is not the best choice for oil and gasoline.
  27. Ebbsspeed
    Ebbsspeed
    Permatex Hi-Tack, part #98H for a 4 OZ can, 98D for a 16 OZ. Can also get it in a spray can, 99GA for 6 OZ, 99MA for 12 OZ.
    I use a lot of the Permatex Aviation Form-A-Gasket, stays pliable, works well.
  28. wbrw32
    wbrw32
    This is 3M part #8001...yellow **** #8003 is black
  29. V4F
    V4F
    from middle ca.
    i used alot of Gaskachinch on my dirt bikes . yes it works well .
    thank you ALL for the ideas . will try them soon .......... thank you again .. steve
  30. hi-tac also comes in a tube its good stuff sticks quick
