Hot Rods Urban ledgends
Discussion in 'The Hokey Ass Message Board' started by Boneyard51, Apr 10, 2018.
  1. Boneyard51
    Boneyard51
    Being kinda new here, I went all the way back to the beginning and read the thread about the most ubsurd claims we’ve heard and determined that those guys are nation wide and running strong. Run into one last week end that had a stock’68 Torino, 390, that would run 9 flat and drove it everyday to work. Well.. I keep hearing the same story now and again and figured it was BS, but was looking at the vintage pictures thread and saw a complete engine blown apart at the crank and sitting on the drag strip. Kinda got me thinking... What I’ve heard many times was a head blowing completely off and coming through the hood leaving a perfectly square hole. Could I get some opinions/ testimony on this legend. Thanks Bones
    Clay Belt and chryslerfan55 like this.
  2. Chappy444
    Chappy444
    the only thing i have ever seen come off the top of the engine is a blower...on a 10,000hp dragster
    every other engine failure i have seen with parts leaving the engine has all been bottom end. (usually the part that leaves is a chunk of the block where the connecting rod tries to escape)... even when a valve falls into the chamber it tends to push the rotating m*** out of the bottom not pop the head off.
    but, lets say we could get the head to totally separate from the block (sheer off +/-17 head bolts with approximate sheer strength of 120,000psi each) you still have to have enough force left to carry the 35lb hunk through the metal hood (probably a hood brace as well)... i really have to say it is probably a BS story... IMHO
  3. DDDenny
    Maybe in the eighth mile!
    MAYBE!
  4. Bandit Billy
    Bandit Billy
    :cool:
    zzford likes this.
  5. LAROKE
    LAROKE
    I've seen the end results of fan blades slicing through hoods.
    Clay Belt and 283john like this.
  6. XXL__
    XXL__
    Or out the back of a C-130.
  7. Vanness
    Vanness
    Was running 10 years ago at a test and tune and saw a balancer go thru the hood and land 30 or so yards away. Thank god not on the bleachers.
    olscrounger likes this.
  8. s55mercury66
    s55mercury66
    from SW Wyoming
    I have seen an El Camino that had a ragged opening in the firewall from a flywheel breaking loose. The exit hole in the top of the cowl was fairly clean. I have also seen tiny slices in a Corvair hood, caused by it's fan shedding it's blades. That was kinda funny, as it took a couple of days for him to figure out what the "tink!" noise was.
  9. lostone
    lostone
    from kansas
    Had a fan come apart, straight up thru the hood. Few seconds later it came back down and landed in the middle of the hood. I was impressed.
    loudbang and King ford like this.
  10. seb fontana
    seb fontana
    from ct
    The above came out of the below.
    Thanks to Loud Bang
  11. '51 Norm
    '51 Norm
    from colorado
    Egads! that looks expensive!
    zzford likes this.
  12. Gman0046
    Gman0046
    The dumbest Urban Legend is the gal who had a Corvette with "if you can beat me you can eat me" painted on it. On this site some HAMBer's even said they saw it.
  13. chevy57dude
    chevy57dude
    That one is right up there with the $20 bill on the dash, and the folks who saw Bigfoot
  14. Wrench666
    Wrench666
    Back in high school a friend of mine put $20 on the dash in his 80’s pos. As the other guy reached for it he 2 footed the brakes. He ate the dash pretty good
    It was an ***hole move but pretty funny just the same
    Andrew
    Clay Belt, 60F250, Terrible80 and 5 others like this.
  15. Boneyard51
    Boneyard51
    That’s the picture that got me thinking about the heads blowing off! Bones
  16. About time to dust off the 710 cap or the Pontiac Goolie or the Coke bottle in the quarter panel myths and the multiple people who saw it happen
  17. There's enough truth to these so that it won't die. I watched a 'Dyno Fails' video a week or so ago and it was pretty amazing some of the 'stuff' that blew off. My favorite was a turbo rice rocket that exploded, shedding more than few external parts, but as the camera panned the carnage the 10" diameter hole clean through the middle of the block caught my eye.
    If you look at a lot of the 'race' blocks for sale, the extra webbing/ribbing added to some wasn't done just for the hell of it... I've personally seen a late SBF block split in half right down the middle. But big loads of boost or nitrous is usually required...
    mad mikey likes this.
  18. lostone
    lostone
    from kansas
    ^^ coke bottle myth^^^
    I had a new caddy come in the shop, it was about a year old and the old lady had gotten rear ended. My job was to pull the quarters, fit the deck and door gaps so the body shop could replace the quarters. Well I got the quarters pulled and shaped and I had to cut a hole in the right quarter to access and pull the trunk floor. Inside the quarter was a big zippo lighter case about the size of your fist and it was full of big washers and nuts with a note that said " how long did it take you to find me?"
    When the lady came to get her car I showed it to her and she asked to keep it to show to the caddy dealer, she said it had been there numerous times for a bad rattle in the rear end. A month later she stopped by and said it was nice and quiet and that had definitely been her rattle.
    So some myths could indeed be true.
    I've found numerous other things, large bolts with nuts and washers etc. Of course after almost 40 yrs of doing this I guess it's no surprise.
  19. tim troutman
    tim troutman
    seen fan blade through the hood 12 bolt parts through the cover my buddy in high school had a 65 chevelle built an aluminum rod engine out of used parts put a good clutch and pressure plate in it slung the disk off some of our friends wanted to go out in it on the weekend bought a napa reman and put in it the first time getting on it slung the disk off the clutch. they took it back for a refund .that kinda fun didn't last long
  20. When I worked at jag, we pulled the dash out of a car and written on the bulkhead was HELLO YOU DAMN YANKEES !!
    Had a Honda in one shop I worked at under the back seat was one of the factory line screw gun zip gun deals stuffed under the seat
    Had a harmonic balancer sepperate on my s10 and when I shut the truck off the outer shell came loose and rolled away.
    They all sound stupid but true!
    Clay Belt likes this.
  21. Word for word, the same story that I've heard a dozen times, except for the Zippo twist. Well played. It's always a Cad and it's always a note asking the same question.
    Clay Belt, low down A and Hnstray like this.
  22. kidcampbell71
    kidcampbell71
    L-E-G-E-N-D .....is that somewhere, sometime, and someone within the HAMB heirarchy won THE National Spelling Bee. I'll go ahead and take you out of the running for that candidate. The search continues .....
    HAMB on, please. Don't mind me ....
  23. lostone
    lostone
    from kansas
    I don't care if you believe me or not. I was there and it happened to me personally. **** happens whether you choose to believe it or not.
    Saxman and Montana1 like this.
  24. DDDenny
    I live in the land of Bigfoot, it's real.
    Just ask @Crazy Steve.
    Ford52PU, mad mikey, enloe and 2 others like this.
  25. 38Chevy454
    38Chevy454
    This is a real urban legend that is 100% false: "It crystallized and broke"
    As HAMB Metallurgist, I can say that this phrase has been stated on HAMB in threads with a broken part. This statement is completely false - because ALL metals are crystalline. That is their structure when solid. It is always crystalline. The reason you might here people say this is because when the uninformed look at a fracture surface it can look crystalline in appearance. Well, duh, because the metal is crystal structure.
    Along the same lines another metallurgy related urban legend: "Chrome plated parts will fail due to embrittlement"
    This one is mostly false, but there is some minor truth about it. Only plated heat treated parts that have high hardness and a susceptible metal (most steels are susceptible) and a high applied static load, can sometimes fail by hydrogen embrittlement. HE will be a failure within 72 hours, many times within a few hours. It is NOT a sustained failure. Any long term sustained cracking is going to be a fatigue crack. Not HE. Fatigue is cyclic tensile loading of the part that initiates and propagates a crack until it finally has sufficient crack length that the part fails catastrophically. Almost anytime you hear that a part was embrittled by plating and that caused it to break will be a false statement. Unless the part failed within 72 hours after being installed and loaded up, it was not embrittlement. Non-heat treated parts will not fail by embrittlement. Only parts like springs, bearings, or maybe some wear type parts are heat treated.
    Clark, belair, mad mikey and 2 others like this.
  26. Boneyard51
    Boneyard51
    Kid, when I was in spelling cl*** in the previous century, they stood us up against the walls of the room and asked us to spell words. If you misspelled a word you had to sit down... I sat while the dumb***es stood! Thought I was pretty smart! Shows doesn’t it! Bones
  27. s55mercury66
    s55mercury66
    from SW Wyoming
    Hey, Bigfoot was the only one who snagged the twenty off mine.. really, a true story..
  28. 327Eric
    327Eric
    I am guilty of writing some disparaging comments on the top of a trans, and behind some parts on a couple of High Dollar muscle cars. It was the end of a very ****py job, and to say I was disgruntled is an understatement.
    Clay Belt, GreenMonster48 and zzford like this.
  29. Rocky
    Rocky
    Classified Editor
    Many times I've heard of lightened flywheels exploding and causing damage but I saw this one myself at the HAMB drags 2 or 3 years ago..
    One of the HAGR cl*** dragsters pulls up to the line running a 302 "Jimmy " with a 3 speed. He comes bustin off the line and at the top of 2nd gear I see something fly out of the rail and over towards the crowd while the rail slows and the crowd goes "OHHhhhhh"! Turns out the flywheel came apart at high RPM and the thing I saw was a hunk of flywheel. It zipped straight over toward the crowd lined up along the fence with cars and trucks nosed up there. The offending piece hit {I think it was} Pork'n******'s pickup's mirror and broke the mirror arm off the truck! Missed everybody but came close to disaster.
    mad mikey and lothiandon1940 like this.
  30. Montana1
    Montana1
    Did someone mention BIGFOOT?
    Ford52PU, enloe and chevy57dude like this.
