Just putting my engine back together and have got stuck on what the ring gap should be. The pistons are forged Ross with a 4" bore. Does the rule of 4 thou per 1" of bore still apply with forged pistons? Should I go for 16 thou gap?
Been a while since I cut rings.... but it seems like it was determined by the type of ring, and not the piston... since they expand at different rates. Like ole Don says ... call the manufacturer. Kamp
It also depends on the engines application, IE: Street, Race, High Heat, Blowers, Turbos,etc. .016 on the top ring can be marginal even on a street engine with todays fuel.
yup, use has more to do with it than anything else, nitrous requires a lot of gap, blowers a bit more than unblown, etc. It has to do with how much heat gets to the rings, which determines how much they expand. If it's just for normal naturally aspirated use, then figure .016" for a mild engine to .020" for a screamer.
