Technical US Royal V Belt Interchange
Discussion in 'The Hokey Ass Message Board' started by BJR, Mar 10, 2025.
  1. BJR
    BJR
    I have a V belt for my Black and Decker valve grinder that I want to find an interchange to a modern belt. The belt that is suppose to fit my machine # 16286-2 is too big. The old belt that fits my machine was made by US Royal and is number 16285. Does anyone have an interchange chart for US Royal belts to a modern belt? It's 3/8 wide and about 21" in diameter. The machine doesn't have much adjustment so I need the right one.
  2. 38Chevy454
    38Chevy454
    If you go to a (real) auto parts store, they should have a tool to measure the old belt and get you one that is the same size. A 3/8 wide belt is typically going to cross to a 13**x type number or a 3L**x number I think. The **x is the length cir***ference of the belt in inches **.x format. So using your 21 inches diam, that is approx a 21 x 3.14 = 66 inches. Which would be like a 13600, or 3L600. But verify with the belt measuring tool, that way you get the right one.
    BJR, vtx1800, warbird1 and 2 others like this.
  3. Budget36
    Budget36
    BJR likes this.
  4. alanp561
    alanp561
    Could you use an adjustable link V-belt? I've found them in 3/8", 1/2" and 5/8". I've used them on table saws and not thrown or burned one up.
  5. BJR
    BJR
    This should be simple, if I could cross the US Royal belt number 16285 to something new.
    Chucky likes this.
  6. Chucky
    Chucky
    I found this chart…
    BJR, seb fontana and pprather like this.
  7. pprather
    pprather
  8. BJR
    BJR
    Except that the belt is 3/8" wide and about 21" long so that doesn't help at all. The US Royal numbering must be before the new numbering system came to be.
  9. pprather
    pprather
    From chart above, 3/8" wide is 12/32" which would be 12-**x.
    When you say 21" long (belt folded in half)?
    Or measured around the outside, using a cloth measuring tape?
    Or cut, so the length can be measured?
    BJR likes this.
  10. pprather
    pprather
  11. pprather
    pprather
  12. Beanscoot
    Beanscoot
    My local NAPA let me buy a selection of 3/8" belts around the anticipated length needed, to take with me to our remote property and return the ones that were wrong. Saved much time.
    BJR and Algoma56 like this.
  13. Can't find a cross reference for US Royal numbers yet, but it's not automotive belt, so try Farm and Fleet or Tractor Supply for fractional HP belt match-up.
    BJR likes this.
  14. BJR
    BJR
    Measured around the outside.
  15. Jack E/NJ
    Jack E/NJ
    from NJ
    3/8" x 21" cir***ference = 3L210 v belt
    BJR likes this.
  16. pprather
    pprather
    Several links àbove.
    BJR likes this.
  17. BJR
    BJR
    Thanks everyone, That should do it.
    Algoma56 likes this.
