Hot Rods Using a Uni-syn carb. syncronizer
Discussion in 'The Hokey Ass Message Board' started by caveman57, Jun 21, 2018.
  1. caveman57
    caveman57
    I have a pair of Speedway super 97's on my flathead. they seem to run OK but I want to syncronize them. When I put the uni-syn on one of the carb with the center part screwed wide open the motor starts to choke and stall. It sounds like I'm choking off all the air. Do I need to open the throttle plates more or turn the idle adjustment screws in to lean the idle mixture down. I've read the instructions but they don't seem to help
  2. saltflats
    saltflats
    from Missouri
    Does it do that on both carburetors?
  3. bchctybob
    bchctybob
    That's baffling. I just pulled out the ol' Uni-syn and opened it up as you say you did. There is clearly more airflow capability than what a carb with closed throttle blades would require. It made me wonder if setting the Uni-syn in place covered an air bleed or bowl vent causing it to stop the fuel flow. But looking at the pictures of your carb, there doesn't seem to be anything that the Uni-syn would cover. Are the mixture adjustment screws on that carb adjusted in or out a lot more than the other carb?
    P.S. I'm no Stromberg expert but I love a good automotive mystery
  4. badvolvo
    badvolvo
    Does not take much to choke out a 97, speedway or stomberg. Running 3 on a 355" mild built sbc. Took a re-jetting on main and idle, as well as stacked air filters to keep it idling proper. One air cleaner limits the flow enough, she won't idle right, no air cleaner it was lean, two seem to work well.
    I gave up on the sync tool on my son's triple webbers, we use a laser thermometer on the header pipes to get them right.
  5. saltflats
    saltflats
    from Missouri
    My experiences with a uni-syn has been that you only put it over the carburetor for a 1/2 to 1 second.
    You adjust it to show some flow, [if you leave it on any longer it can choke the carb down] then work back and forth on the carburetors to dial them in.
  6. Mike VV
    Mike VV
    from SoCal
    Sounds odd to me. I've used them a fair amount over many years, and yes, even on 97's (original ones), Rochester's also tuning a Man-a-Fre.
    You can leave them as long as you like as long as you are just testing at or near idle speed.
    See bchctybob's comments.
    Mike
  7. prewarcars4me
    prewarcars4me
    from Bhc, AZ
    This is the only type I use anymore. My uni sync collects dust. STE-SK-2T.jpg
    19Eddy30, zzford and VANDENPLAS like this.
  8. Blue One
    Blue One
    from Alberta
    Oh joy, post it and don’t tell anyone what it is or how it works. :D
    Cosmo49, VANDENPLAS and 3340 like this.
  9. jimmy six
    jimmy six
    I use one on my dual quads and it's been perfect for yrs. A friend uses his on 97's and doesn't have your problem..
  10. bchctybob
    bchctybob
    I used my Uni-syn on my roadster (292 sbc w/3 Strombergs) with good results and no problems. Lately, I use it on my wife's Corvair with mixed results. Several of the Corvair club guys recommended the type of synchronizer shown above and one uses a Magnehelic differential gauge hooked to the vacuum port. Both are available on epay, prices vary. Used properly, the Uni-syn shouldn't cause it to die during adjustments unless your engine has a really big cam, heads, etc. There's something else going on there. We need some wisdom from Carbking and Squirrel.
  11. oldolds
    oldolds
    I got a guy that can fix carbs!
  12. Petejoe
    Petejoe
    from Zoar, Ohio
    I agree with Mike. You simply adjust the flow rate on synchronizer.
    Another note.
    You must unhook the linkages to both carbs. Set them evenly pulling the same amount of air, then adjust the linkage to keep the carbs pulling the same. Fuel/air adjustment screws are used only for fine adjustment.
    They will not allow you to get the carbs close initially.
    3340 and rfraze like this.
  13. Kan Kustom
    Kan Kustom
    I will be watching this one. I just boought a Uni Syn for my 348 three deuce. Never had a need before.
  14. Blues4U
    Blues4U
    from So Cal
    The throttle linkage on your 348 is not progressive?
  15. 19Eddy30
    19Eddy30
    from VA
    This is the one I also use when I set up my flatty ,
    Just to Balance Carbs , then I use a wide band 02 for all other turning, plug reading is long gone with gas off pump ,( modern gas )
    Another note on 2 or 3 97s /stombergs carb set up ,
    Motor that makes 300hp & up , they are just for looks ,not enough CFMs , switch to R2Gs , you will be much happer
  16. prewarcars4me
    prewarcars4me
    from Bhc, AZ
    I even modified a velocity stack with a lid that has a hole and an adjustable"vent" so I can use it on most carbs, even 4 barrels.
  17. rfraze
    rfraze
    Some carbs require a spacer to get Uni-syn above carb body. Example 2659483899[1].jpg
  18. flatjack
    flatjack
    My ear is my Unisyn.
    saltflats likes this.
  19. prewarcars4me
    prewarcars4me
    from Bhc, AZ
    It works just like a uni sync, only better. Figured with the thread being what it is, most could figure it out. :D
    Basically goes on top of your carb and as air flow goes through it, the needle moves to tell you how much. I bought mine 20-25 years ago at Karls VW in Mesa, AZ. Just google uni sync or carburetor synchronizing tool, and the world is yours ;)
    Blue One likes this.
