Technical Using alternative rears for 32 Ford
Discussion in 'The Hokey Ass Message Board' started by MERCURYGUY, Oct 19, 2025.
  1. MERCURYGUY
    MERCURYGUY
    I happen to see an article where a rodder was using a 51 flathead with a 39 ****** like me but had a 40 rear instead of the 32 I am running. I had heard that the rear on the 40 would have to be shortened. What is involved in that ? can some one there tell me what is involved and who can do the work say the the Connecticut area ? Thanks Tom
  2. pprather
    pprather
    I ***ume you already have the hydraulic brakes.
    What is the reason for switching the 32 rear for a 40 rear?
  3. alchemy
    alchemy
    If you have an early 32 rear, it has a pinion without a bearing on the snout. If you have a later 32 it has a bearing. A 40 rear is no better than the late 32 rear. No reason to swap.
    GuyW likes this.
  4. Fogger
    Fogger
    My '32 Roadster was a banger with the unsupported pinion. I found a '40 rear axle with a Zephyr Columbia that has the speedometer drive off the right side axel. Other than notching the rear spring to fit the crossmember and having the torque tube and drive shaft shortened it was an easy upgrade. I had a set of early artillery wheels and had the rears widened 2" on the inside. The later Ford axles are wider and by changing the wheel width the rear tires are closer to the body. Unfortunately the fellow who ***embled my Columbia has p***ed but there are others who do the driveshaft torque tube mods.
    UNCLECHET, dwollam and cactus1 like this.
