Using an in-radiator trans cooler for power steering?
Discussion in 'Off Topic Hot Rods & Customs' started by Anderson, Sep 14, 2024.
  1. Anderson
    Anderson
    nevermind, dumb idea
  2. mohr hp
    mohr hp
    from Georgia
    I know ford had some PS coolers, but I always wondered how hot the fluid gets? Is it really necessary to cool it?
  3. partssaloon
    partssaloon
    Got rid of the whine my pump had by installing a cooler
    rockable likes this.
  4. Anderson
    Anderson
    From most of what I’ve read it would probably do more to heat the fluid using the radiator cooler vs having none or a stand alone cooler. Idea abandoned.
  5. ottersea
    ottersea
    For what it is worth this is the one that came with the PS pump from mid 80s GM I believe.
  6. RodStRace
    RodStRace
    All the big 3 had various PS coolers for HD and police use. All were small separate coolers like shown.
    I'd guess that would just require some creative line selection for routing on your project.
  7. Deuces
    Deuces
    How's about adding synthetic power steering fluid???... That should make it run a little cooler.....
  8. stealthcruiser
    stealthcruiser
    Could the radiator cooler, withstand P/S pump pressures and surges?
  9. AldeanFan
    AldeanFan
    Some foxbody mustangs had a 2’ loop of steel line in front of the radiator that acted as power steering fluid cooler.
    I had to add a cooler to my Autocross car because it would push fluid when it got hot.
    I just used the smallest oil cooler I could find.
    Deuces likes this.
  10. RodStRace
    RodStRace
    Cool the return side (low pressure). But as many have pointed out, the standalone is going to be cooler, lighter, commonly available. Unless you have the radiator with built-in AT cooler and not using it, it's not really a great plan. Even then, you are heating it to engine temps.
    https://www.bing.com/shop?q=power+steering+fluid+cooler&FORM=SHOPTB
  11. Mike VV
    Mike VV
    from SoCal
    I'd say not a chance !
    I seriously doubt that the power steering runs 190°+ degrees...like the engine coolant does !
    Just get a more proper radiator/cooler/heat exchanger. Mostly by size. The power steering system doesn't need a 10" x 10" radiator.
    Mike
  12. Just use an inline heat sink cooler. I used the cheapest Summit Racing heat sink style cooler mounted to the frame rail next to the pump and saw a 40F drop in PS fluid temps in the summer.
    Balljoint likes this.
