Art & Inspiration USING THINGS NOT DESIGNED FOR HOT RODS & CUSTOMS
Discussion in 'The Hokey Ass Message Board' started by HOTRODPRIMER, Mar 5, 2026.
  1. shorrock
    shorrock
    from Germany
    Used a chromed headlamp from a bicycle to insert the blower gauge. Made the bezel ring from aluminium and polished it. The gauge is filling the headlamp almost complete but I managed to put a little green LED in as well. The foto shows a lot of dust from last years tours - time for a clean-up.
  2. Pav8427
    Pav8427
    Spotted at a show a couple years back.
    64-65 Dodge short box. Real low. Had to cut a hole in box for rearend pumkin clearance.
    Mounted a suit case to to cover the hole.
    Had it painted up like an old pin stripers case.
  3. DDDenny
    Shifter cover made from a small cast aluminum cooking pot.
    The switch box was originally used as an electronics enclosure.
    I did repurpose a B&M auto shifter cover for an E-brake handle cover.
  4. skooch
    skooch
    It’s the “ I don’t quite know what I’m looking for but I’ll know it when I see it.”
    brad2v, Ned Ludd, porkshop and 17 others like this.
  5. jetnow1
    jetnow1
    from CT
    I made the fan shroud for my truck out of the drawer from the bottom of out of old stove, already had nice rounded
    corners.
  6. HOTRODPRIMER
    HOTRODPRIMER
    Been there. HRP
    Ned Ludd, porkshop, Sharpone and 4 others like this.
  7. 36cab
    36cab
    My first vehicle when I turned 16 in the 1970s was a 1955 Ford F100. My dad put a chrome 1956 F100 grill in it and he used pie plates behind the headlight buckets to gain enough room for the 1956 grill to fit.
  8. Bugguts
    Bugguts
    20260306_145718.jpg 20260306_145917.jpg Just got my Chrome box Flange for steering wheel lower cover from Ebay today.
    Steering wheel tube is 1.5 polished stainless steel exhaust tubing from Ebay.
    ( thanks LG Speed and Custom) for the steering tube idea.
    Still mocking up carpet size, thus the paper and tape.
  9. twenty8
    twenty8
    Aaahhhh...... The same method we use to find a wife.;)
  10. nochop
    nochop
    from norcal
  11. DDDenny
    To fill in the open space adjacent to the seats I got a couple of s**** fibergl*** panel cutoffs from a local shower mfg. sorry, not the best photo, it's the only one I could find.
    Sharpone, VANDENPLAS, Dave Mc and 5 others like this.
  12. Recently restored this Signal Stat and was looking for options for the missing green plastic and went for a wander through the local "cheap shop" craft section and found these "rhinestone gems" plenty of options on the sheet and the lime gems just sat in the hole perfect and illuminate great with the globes but I have indicators in the gauge panel so these will just be aesthetically used. 1000018907.jpg 1000018909.jpg
  13. Okie Pete
    Okie Pete
    The plastic indicator bulb divider on my Shovelhead dash had crumbled from age . So I used plastic pill bottles cut to length and taped together. I used plastic lab sample tubes to imitate the vacuum tubes in a radio I adapted to Bluetooth
  14. nochop
    nochop
    from norcal
    Why do I relate to shovel head and pill bottles……back in the day……and now…..
    Sharpone, Dave Mc, Okie Pete and 4 others like this.
  15. Don't forget about **** Spadaro's sink pipe to re bush '39 pedals (clutch).
  16. Sharpone, Okie Pete and A 2 B like this.
  17. pirate
    pirate
    from Alabama
    I had an issue where the electronic speedometer sender interfered with the transmission/driveshaft tunnel. I also wanted a way to remove the sender without removing the transmission because I was unsure if it would work. I took a muffin/cupcake pan out of our kitchen (I replaced with a new one) and sawed one of the cups away from the others. Because I also needed a flange I took some aluminum sheet metal and formed a handle a flange as well as a hole matching the the diameter of the hole in the pan. I bonded the two together with JB Weld and sanded the joint smooth. I then waxed the cup and made a slug out of body filler/bondo and pulled it out after curing creating a two part tool.
    I then cut some fibergl*** wetted it with resin put it in the cup put the slug in the cup on top of wet fibergl*** and clamped with a C Clamp. After it cured pulled the slug out and repeated the process with another layer of fibergl***. When everything was cured took the fibergl*** cover sanded it round, drilled holes in flange and painted it. Then installed on the transmission/driveshaft tunnel. A fair amount of time to make tool and cover but think the cover looks good and accomplished what was needed.
  18. Dave Mc
    Dave Mc
    When I built my 33, added a trunklid I used the cap above the rear window (roof) and inverted it for the pkg shelf, I Woodgrained the Pkg shelf, had to create a latch with linkage to lock the lid, I used a Clutch Handle from a Harley Davidson to activate it.
    Ned Ludd, Sharpone, Okie Pete and 4 others like this.
  19. Dave Mc
    Dave Mc
    I needed a Sideview Mirror for my 33, didn't want to drill holes in the door, so I used a motorcycle mirror and welded a Washer onto the stem and used the bolt from the Cowl lamp to attach it.
    i.rant, Ned Ludd, Sharpone and 4 others like this.
  20. hotrodjack33
    hotrodjack33
    I used parts of my wife's "easy glide" cross country ski machine to build the tilt front end on my old '40/'37 Ford pickup...she was pissed:eek:
    brad2v, down-the-road, 69fury and 9 others like this.
  21. pprather
    pprather
    To route the wires into the headlights I used an extended flare nut from the plumbing department at the hardware store.
    For some reason it screwed on to the 33/34 hollow headlight stud.
    Painted it hammertone silver. A small stainless Allen screw holds the stainless conduit in place.
  22. Okie Pete
    Okie Pete
    IMG_4227.jpeg She lost the place where she hung her coats and extra clothes
  23. blue 49
    blue 49
    from Iowa
    The trim ring around my gas cap is a kitchen sink strainer basket with the bottom cut out. I've got a better pic somewhere, but I can't find it. These could also be used to p*** exhaust pipes thru a flat panel.
    Gary
  24. 409 Bob
    409 Bob
    The short rear roll pan is made from the corners of a gas tank, and the center of a f-40 florescent light fixture. It doesn't quite cover my latest fuel pump. DSC01371.JPG
  25. 409 Bob
    409 Bob
  26. I removed the factory glove box from my '33 dash to run a gauge panel, I then repurposed a surplus 50 cal. ammo box mounted under the dash and removable so I can be taken from the car if I'm carrying something I don't want to leave unattended.
  27. ERguitar
    ERguitar
    Fuel fill recess is a chain cover off of a snow blower. KIMG2139.JPG KIMG2141.JPG KIMG2141.JPG
  28. Dominick Hide
    Dominick Hide
  29. jimmy six
    jimmy six
    Maxwell House or Hills Brothers?
    Okie Pete, Dave Mc and porkshop like this.
