V-twin balance
Discussion in 'Off Topic Hot Rods & Customs' started by dumprat, Sep 21, 2008.
  1. dumprat
    dumprat
    from b.c.
    What percentage of bob weight do you use to balance a V-twin. Does the angle of the engine matter. eg.45 or 60 degree?
  2. hogbldr1
    hogbldr1
    from ohio
    s&s recomends 60 %
  3. Yes, the angle matters a great deal. Indian and Harley use different balance factors due to their different cylinder angles. BMWs need almost no balance factor (it's arguably a 'V' twin, albeit one with a 180º angle.).
    Also useage matters: if your cruising at, say 2500 rpm, you'll use one balance factor, whereas if your road racing, it's another factor.
    Best is to given the entire rotatating ***embly to someone whom you trust.
    Cosmo
  4. zman
    zman
    from Garner, NC
    I call it an opposed twin. :D
    Don't forget the Ducati twins with their 90 degrees.
  5. GuyW
    GuyW
    Does anyone have the S&S bob weight that they could make a simple measured drawing of, so I can machine one to the 1000 gram weight? Its the last piece I need for my balancing kit (S&S no longer sells the kit or any parts thereof)
    Thanx
  6. deathrowdave
    deathrowdave
    from NKy
    Dont know anybody that has any parts , but a couple of running engines . Funny thing both my old Shovels are rather smooth until about 70 Mph , go through the shakes on the way up , smoothes out at about 75 , only issue is on the way back down it seems worse to go through . Old Dudes just keep running
    Illustrious Hector and GuyW like this.
