V8-60 front axles: an appreciation
Discussion in 'The Hokey Ass Message Board' started by 50Fraud, Jun 22, 2009.
  1. 117harv
    117harv
    belmontsanchezchassis1.jpg IMG_4827.jpg PICT0030-17.jpg 360.jpg More.
    Dwight schneider and Paul like this.
  2. carbuilder
    carbuilder
    I have an original V8 60 axel for sale $400.00 plus shipping PM me if intrested.
  3. turdytoo
    turdytoo
    FWIW- Back in 1963 I worked for Chuck Tanko at Fresno Speed Center. We sold what we called Bell Drop axles that were made in Fresno by Ron Asmajian(SP). I was told that he made them as a side job and had them plated at California Chrome there in Fresno. When we sold an axle we would call Ron and he would bring us another one. My model A roadster that I sold in 1967 had one when I bought it. It seems like quite a coinsidence that Ewing started Superbell in Fresno also. **** Baskin probably knows the real story.
  4. carbuilder
    carbuilder
    I have sold the V8 sixty axel thanks
  5. onekoolkat1950
    onekoolkat1950
    I want one!!!!!!
  6. 3wLarry
    3wLarry
    from Owasso, Ok
    I got one for sale :)
    kidcampbell71 likes this.
  7. titus
    titus
    I have 4 total now, 2 each of the different styles, one of them has the little perch "wedges" remove and holes welded shut, luckily i was able to take a punch and knock out the slugs that filled the hole and then had a buddy make some new "wedges" using the one from my axle that has fallen off as a pattern.
    i did a post a while ago on ford barn and had weighed axle for comarison over the "Weight saving argument" here the weights
    v8-60 weight, 17.5 pounds,
    33-36 axle weight, 20.5
    32 heavy axle weight, 23 lbs
    heres on i picked up a year ago one of our big swaps, it was $100 and spindles on it, they were welded on the ends but i very carefully removed them and didnt hurt either the spindles or axles, so that was nice, i took and started smoothing it out, hopefully it will be plated someday.
  8. 117harv
    117harv
    Paul and 3day like this.
  9. Jalopy Joker
    Jalopy Joker
    Paul likes this.
  10. Moriarity
    Moriarity
    SUPER MODERATOR
    My outlaw clone has one too!
  11. I may have said this before but "IF" I had one to copy there would be repops for the guys who just cant swing or find originals. They could be had with or without bungs for those who desire a coil sprung front axle.
    But the "IF" is the operative word here I suppose. LOL
    I have always loved these axles, too bad there are not more of them around for me to appreciate. ;)
  12. gnichols
    gnichols
    from Tampa, FL
    I don't think I posted this before, but a recent profile on Magnum Suspension in the April 2015 Street Scene indicated they are planning on making "smiley" tube axle like these. I certainly welcome the idea - the sooner the better - and have just started to pester them about it. Gary
  13. 29 Speedster
    29 Speedster
    from Colorado
  14. -Brent-
    -Brent-
    Fellas, I have a couple questions. I have a v8-60 tube axle I was planning to put under my 32 ch***is. I figured I would run it in a spring over configuration that I have seen done in tons of photos before. Since the perches are spaced wider, what spring do I run?
  15. Frames
    Frames
  16. Frames
    Frames
    1940 FORD chassis. 4325 shop 008.jpg raise money 11-18 12 020.jpg Story time. Ran a want ad in Early Ford Times for a 60 tube axle. Received a reply 1 hour away. He has a 1940 ch***is for $500.00. Tube axle a little pitted. Had a 42-48 rear end. 3.54 gear. R&P was JUNK. Frame was really nice. I gave it away for $200.00. The good 3.5" wheels were gone. Sold the side shifter for $150.00. I used the bones on a race car. I'm keeping the axle and spindles. Sold some of the brake parts. I have 2 NOS axles bought years ago. Eat your heart out.
  17. Frames
    Frames
    I have a Super Bell [I think] tube axle with only 1" drop. Don't know why they bothered making it. It sure looks like a 60 axle, but the distance from the perch bolt to the king pin is greater. That's a good thing for tighter turns. It does look a lot like a 60 axle. The outer ends are even a little oval. Can't find the picture right now.
  18. steel rebel
    steel rebel
    I know I should keep my mouth shut "BUT I WON'T" Do you people "who can't find a V860 tube axle or a Steel T body ever go to a swap or go on ebay? I see them at big swaps almost every time I go. The reason they aren't made aftermarket is because they are still out there. Okay 4 or 5 hundred dollars. I paid $80 in the '80s then another $100 for chrome.
    Okay that is off my chest.
  19. orangeamcs
    orangeamcs
    I bet bcchoppit could make a similar axle for anyone wanting one.
  20. scrap metal 48
    scrap metal 48
    I have one under a 34,000 mile 1938 ford V8-60 I would sell with wishbones for $550...
  21. BCCHOPIT
    BCCHOPIT
    I am working on a axle that has a smile. But it would be round tube and not that ***y Oval-ish ford shape
  22. 28dreyer
    28dreyer
    from Minnesota
    Profile Page
    28dreyer
    from Minnesota
    New
    Here's mine made from 4130 about 8 years ago.
    Marked off every 1/2" and bent in a tube bender mounted on a metal shaper to get identical strokes. IMGP5668.JPG
    volvobrynk and dos zetas like this.
  23. LOU WELLS
    LOU WELLS
    from IDAHO
    I LEFT MY LAST TUBE AXLE IN A 40 DELIVERY 42 YEARS AGO AND REGRETTED SELLING IT SO THIS ONE STAYS IN A SAFE PLACE!!!
    volvobrynk likes this.
  24. dirty old man
    dirty old man
    Question for all:
    For years I have heard people comment on tube axles, and even read it in a mag, IIRC it was Rod & Custom.
    They all said you shouldn't run tube axles with either split stock radius rrods or hairpins, only with stock V wishbone or 4 bar.
    Anybody run a tube axle for any length of time on a hot rod frequently driven on public, less than perfect roads without trouble? I have hairpins and an I beam axle that is chromed and starting to peel. If I remove it someday, I'd rather replace with a chromed tube than a rechrome on the current I beam.
  25. -Brent-
    -Brent-
    @dirty old man there's been lots of cars over the years to have run them without issue. Here's a good thread discussing it.
  26. steel rebel
    steel rebel
    Dirty
    In theory it doesn't work. In reality I and others have been running them for years with no trouble. When I visited the Indy 500 museum I saw old race cars with the same front suspension as I am running. If you are building a "rock crawler" where the suspension moved a foot or more I would say no don't do it but on an old hot rod where it only moves a couple of inches it's fine.
    Gary
  27. Gary Addcox
    Gary Addcox
    I remember conversation about Ford's tube axle from the late '50's. I also remember guys complaining about them being weak, apt to snap, so I never searched out one because of that apparent flaw. The complaint stemmed from the axle being designed for lighter weight, namely the 60 HP flattie. Just wondering what others think.
  28. 2OLD2FAST
    2OLD2FAST
    from illinois
    Most , myself included , tbucket guys run tube axle/split bones/hairpins on the street , I've logged 40K miles I know 1 guy pushing 200K , I think it must work !!!
    dave
  29. 117harv
    117harv
    Guys, this is an appreciation thread for V8 60 axles, there are hundreds of other threads where one can discuss tube axles and their attachments.
    lothiandon1940 likes this.
  30. dirty old man
    dirty old man
    ^^^^^^^^^^^^,Well sho nuff! How are you gonna appreciate them iff'n you don't know if they will work or break on your car. HUH????
