i have a stock model a engine and trans, w/ a lightened flywheel, have been told i can use a v8 pressure plate and a different clutch, need advice as to what i need and what i have to modify besides the pressure plate? Thanks
If you have the flywheel cut correctly all you need is to have it indexed and drilled to accept a stock 1940 Ford 9" pressure plate. uses a stock 9" disc
