vacum port
Discussion in 'The Hokey Ass Message Board' started by pokey, May 12, 2013.
  1. pokey
    pokey
    I was wondering, Is it best to get the vacuum for your automatic trans(turbo 350) from the intake manifold or the back of the carb? Is there a difference? Does the carb do something for the performance of the trans as get goes though it's paces?
  2. mustang6147
    mustang6147
    from Kent, Ohio
    Normaly there is a port behind the carb on the intake.
    you can use any constant vacuum port, that is a good strong source for vacuum.
  3. vtwhead
    vtwhead
    GM used direct manifold vacuum right from the back of the manifold. Same place the booster eas connected. You do not want ported vacuum from above the throttle blades of the carb.
