Technical Vacuum Brake bleeder ?
Discussion in 'The Hokey Ass Message Board' started by Blue One, Oct 31, 2015.
  1. Blue One
    Blue One
    from Alberta
    Any experience with them and recommendations on the best one to buy ?
    Any features to look out for ?
  2. 2OLD2FAST
    2OLD2FAST
    from illinois
    I've used my mityvac for over 20 years , slow , but works fine !!
    dave
    WDobos likes this.
  3. Rusty O'Toole
    Rusty O'Toole
    Built one out of an old refrigerator compressor, a pickle bottle, a tin can and a piece of wood. It worked great. I could start with a bone dry brake system, and bleed it perfectly in half an hour and not get a drop of brake fluid on the floor.
  4. Texas Webb
    Texas Webb
    Neat setup,any pictures?
  5. Two shabby
    Two shabby
    Use gravity. And hook a vacuum hose to the open bleeder and use a blow gun and blow air past the end of the vacuum hose to create a vacuum to get things moving. i have had good luck with it. And you prob have the stuff hanging around.
  6. 302GMC
    302GMC
    from Idaho
    Surgical tubing & a wine bottle ...
  7. Chucky
    Chucky
  8. EZ Cool
    EZ Cool
    Alliance Vendor
    from Slaton TX
    Problem I have found with vacuum bleeding brakes is that if the rubber cups in the wheel cylinders do not have expanders (older wheel cylinder springs act as expanders) you can pull air past the rubbers into the cylinder instead of pulling brake fluid from the MC. I prefer to gravity bleed or pressure bleed from the MC.
  9. unkledaddy
    unkledaddy
    I tried one once and had a big problem with air being drawn in past the bleeder screw threads, even after
    using teflon tape on them to get a tighter fit. YRMV
  10. buck 32
    buck 32
    from Maryland
    I use this from Griots garage. Works very well.
  11. LAROKE
    LAROKE
    My Mitivac hasn't been used since I got a Motive Power Bleeder.
  12. Atwater Mike
    Atwater Mike
    I use a 12" piece of aquarium tubing, fruit flavored brake fluid, and a neighbor I hate for the vacuum.
    302GMC and 31Vicky with a hemi like this.
  13. unkledaddy
    unkledaddy
    ^^How neighborly of you Mike.^^
