Technical Vacuum Nightmare
Discussion in 'The Hokey Ass Message Board' started by Cameron Kahill, Nov 15, 2022.
  1. gimpyshotrods
    gimpyshotrods
    Dude, please don't talk about my childhood here.
    Adriatic Machine and bobss396 like this.
  2. Tickety Boo
    Tickety Boo
    from Wisconsin
    750 rpm idle is not bad, how does it run and drive in its current state ?
    Is there any oil on the intake floor or the plugs ?
  3. pprather
    pprather
    Well, I think we have driven the OP off this site, because once again, we have trouble staying on topic.
  4. X38
    X38
    That's one way to look at it.
    On the other hand, there's been a total lack of OP feedback from early on, which would have helped keep things on track.
    Unfortunately it's another case of a 1 post OP thowing a bomb and disappearing.
    (And we know he likes to throw things.;)) Eventually people will make their own entertainment.
  5. squirrel
    they work fine at idle, it's just going down the road with the throttle open, that they don't work
    theHIGHLANDER likes this.
  6. Can't drive him away if he never comes back! Has not been back since original post.
    Others get upset if answer is not posted in first 5 min.
    "ain't the HAMB great?"
    Ben
    Happydaze and bobss396 like this.
  7. theHIGHLANDER
    theHIGHLANDER
    Stay tuned bud, in a future season of my build thread I'm going to address my cheap and simple solution to vacuum wiper consistency. Beyond that, I recently flipped a **** ton (official measure) of fuel pumps. A**** then was a Rambler or 2 that had 2 stage fuel pumps, 1 stage for vacuum. All my Packard restoration wipers did stay working while running down the road but would slow a little when the long pedal got pressed a bit more. Then again I dunno how important this is to ya but worth a comment.
  8. squirrel
    Not real important to me, since rain-x works pretty well most of the time it's going down the road. The Rambler has a vacuum pump on the NORS fuel pump, but it doesn't seem to do anything to help the wipers. But then, it's not a Packard, either.
  9. theHIGHLANDER
    theHIGHLANDER
    BBCs engines are often decked, if for no more than to get the surfaces right which has taken as much as .020. Milled heads exacerbate the problem which then require a milled intake. It may bolt up but will never seal up the intake as it should. Conversely, if you have a used intake that was milled for the reasons as stated above they too will bolt up yet might be ****ing through the lifter valley, but that may give a lot of smoke or oil fouling. A vac reading at the valve cover vent hole may show that, may not.
    And since the O/P hasn't returned maybe some of this helps others but I hope he returns triumphant on his 396 powered steed to tell us of his victory.:rolleyes:
    squirrel likes this.
  10. squirrel
    My 396 still has original mating surfaces on the heads and block.
  11. andyh1956
    andyh1956
    We oughtta have a contest. The player has to start at the very last post of a thread & then try to guess what the OP's original question was about...:p
