Hello! I’m looking to block off the vacuum line for my distributor, as I’m going to an electronic setup. I need to locate a vacuum attachment to the back of the throttle body that is short enough to cover the holes that served the distributor line. Any ideas where to find one? I just need to connect the wiper vacuum line that goes back through the firewall. Thanks in advance!
Drill the threads from a 3/8 hex nut & slide on the stub in place of the dist vacuum fitting. Add a washer if you need more thickness.
