Vacuum pump
Discussion in 'The Hokey Ass Message Board' started by redlineracer42, Mar 27, 2011.
  1. Hi,Kinda off topic but it seems a couple years ago someone told me about that new Mustang Cobras run an air pump that can have the wires reversed and use it for a vacuum pump/crankcase evac. system on my Chevy. Am I dreaming this or can some of you Ford guys help me out?Thanks Redline Racer
  2. Capt Crash
    Capt Crash
    from Colorado
    I know that Ford Powerstroke trucks use a vacuum pump. You can pick them up on ebay.
    Brian
  3. Tanks Brian! I'll check it out!
  4. big duece
    big duece
    from kansas
    Lots of bracket racers use them, I had a 780hp 505 bbc and it picked up 30hp just bolting on a crankcase evac system. Oil pressure seem to move up and down on dyno pulls with out it, and was rock solid with evac system in place.
  5. V4F
    V4F
    from middle ca.
    big duece , what pump did you use ?
  6. big duece
    big duece
    from kansas
    I have since sold the car, and the dyno time was during that transition. I believe it was moroso. I can find out.
  7. Weedburner
    Weedburner
    from Wa State
    I use the Cobra style pump on my OT car, pulls 4-5" Hg on 12v. No need to reverse the wires, it has in/out ******s to connect 3/4" id rubber hose on both inlet and outlet sides. Needs a slight voltage drop to run constant, they will overheat in about 1/2 hr on 14 v, melts the brush holder. Here's a typical pump mounted under my dash...
    PN# on mine was Delco 215-425, Cobra pump is basically the same with slightly different outlet locations.
    Around $100 new from Amazon when I bought it.
    swe64 and loudbang like this.
  8. V4F
    V4F
    from middle ca.
    thank you .. steve
  9. Don's Hot Rods
    Don's Hot Rods
    from florida
    What do you do with the plumbing side ? Do you just **** air out of a valve cover and the other side into the open atmosphere , or do you return it back into the carburetor ?
    Don
  10. 270ci
    270ci
    Usually does not go back to the carb, but to some kind of catch can with a coalescing agent or at least an exhaust filter, due to oil mist that is pulled out as well.
  11. Don's Hot Rods
    Don's Hot Rods
    from florida
    Hmm, catch can first before the carb ?
    Don
  12. 270ci
    270ci
    Crankcase vacuum pumps are used in apps involving higher cylinder pressures, such as blown or turbo motors, to improve ring sealing. They aren't intended as positive crankcase ventilation systems, so there is no need to route back to the intake. It's mostly used for racing, although I ran one on my avatar's blown six, which was a street motor. Most are belt driven, but apparently electric ones are now available for less parasitic loss.
    Sorry, don't mean to highjack the thread. Caring on.
