Technical Vacuum Question 350 Chevy
Discussion in 'Traditional Hot Rods' started by PeggySue, Oct 1, 2018.
  1. PeggySue
    PeggySue
    The setup I have is PVC valve in p***enger side cover with hose to carburetor base. Also have breather cap on drivers side cover, will this cause vacuum loss?
  2. town sedan
    town sedan
    No. You have to have a way for the fresh air to get in after the bad air is ****ed out through the PCV valve.
    -Dave
  3. MantulaMan
    MantulaMan
    Pcv valve works by closing off at high vac*** (eg at idle) and opening at low vac*** (eg full throttle). There will always be some vac*** lost through the pcv system but it should be minimal. If the valve is faulty it can ****s in too much air through and lean out the mix causing the engine to run rough and be hard to start. If you suspect this might be happening then pull the tube off the valve cover and stick you thumb over it.
    Sent from my SM-J320FN using Tapatalk
    Model A Vette likes this.
  4. Ottomotive
    Ottomotive
    from Arkansas
    Yes, how much is determined by the number valve you use. The larger CID the engine will use a valve with more loss than a smaller CID engine. The valves look the same except for the number. Be sure to use a breather for it that has an element to be sure the in coming air is clean.
    46international and Elcohaulic like this.
  5. PeggySue
    PeggySue
    OK Thanks. The engine runs and idles good. Installed front disc brakes, dual master, 7"booster, don't seem to have much vacuum, haven't put a gauge on it yet but have hard pedal to get brakes, Did the pump brakes up and hold ,start engine and pedal doesn't drop at all. Had even installed a vacuum canister reservoir.Will have to do some tracing and checking hoses/fitting.
  6. squirrel
    did you connect the brake vacuum to the same place the PCV vacuum is connected? or did you connect it to the manifold, directly, to an appropriate sized fitting?
  7. PeggySue
    PeggySue
    Valve could be problem, I installed the one that came with the valve covers. Breather is the doom type with the venting under the cap.
  8. MantulaMan
    MantulaMan
    Bleed the brakes again. Problem may not be vac***. Also brake booster should have direct manifold vac*** and not have a pcv on it. Pcv line should be separate.
  9. PeggySue
    PeggySue
    Ran off the manifold port behind the carburetor to the reservoir canister, then one line from canister to booster and another line to the ******. There was 2 exit ports on the canister.
  10. PeggySue
    PeggySue
    Bench bleed the master, and bleed all brakes starting with the farless away. The pvc goes from the valve cover to the back of carburetor base, not in the vacuum line
  11. squirrel
    pictures would be helpful.
    The transmission vacuum line needs to be connected directly to the manifold also, not to a reservoir.
  12. PeggySue
    PeggySue
    So I would have to Tee off the manifold and run one to booster and one to ******
    squirrel likes this.
  13. PeggySue
    PeggySue
    I get a picture and get it on here
  14. Mr48chev
    Just thinking on the brakes, you have the check valve in the vacuum line to the booster installed in the right direction if you have one of those valves that you cut the line and put it in the hose?
    That could be with the vacuum reservoir too. Hoses backwards and it doesn't work.
  15. squirrel
    Most or all modern add on boosters include the check valve in the plastic fitting that is on the booster, where the vacuum hose connects.
  16. PeggySue
    PeggySue
    The ****** hoses is at the very back of canister, hard to see. The only fitting that came with canister goes from canister to the booster
  17. PeggySue
    PeggySue
    The valve was installed in the booster, didn't have to cut and install in line
  18. MantulaMan
    MantulaMan
    Just trace the fault. Is booster getting enough vac***? If yes the booster is at fault. If not then trace the vac*** lines back to the carb by pulling the hoses and checking for vac*** at idle. If engine wasn't developing vac*** it wouldn't run. If you have vac*** everywhere then you may have a leak. To find the leak spray brake clean on joins and listen for change in idle.
  19. squirrel
    I suggest you do an experiment...remove the reservoir can, connect the brake booster and the transmission to a T fitting on the intake manifold, and see how it works.
    Saxman likes this.
  20. town sedan
    town sedan
    Why the vacuum reservoir? Is the cam a large grind that produces little vacuum?
    I've never used one, but other folks have reported poor results from the small aftermarket brake boosters.
    -Dave
  21. PeggySue
    PeggySue
    Will try the tee experiment tomorrow and report back, if no change will try tracing as Mantula Man suggests
    MantulaMan likes this.
  22. squirrel
    I have little experience with those little boosters, but it's similar to what we see here...the booster is just too dang small.
  23. PeggySue
    PeggySue
    The motor was rebuilt when I bought the car, owner said it had a mild cam, probably over kill on my part just thought it would be better
  24. squirrel
    sometimes it's better so see if there is a problem, before you try to fix it.
  25. PeggySue
    PeggySue
    That's what I was wondering after reading some older post. I bought the entire setup from Speedway, Firewall pedal ***embly, 7" booster, dual master. I bought the tool gauge for setting distance of the pushrod between the master and booster so pretty sure that's set right.
  26. PeggySue
    PeggySue
    Yes, don't fix it if it ain't broke.
  27. Ron Emerson
    Ron Emerson
    You need a lot of vacuum for the booster I would not worry about the trans modulater right now. The fitting on the intake manifold should be on the larger hole size about a 3/8 inch opening just for the booster. Don't know about the canister except what was stated before about the cam. Put a vacuum gauge on the manifold fitting and read what you have. Should be at least 14-18 inches of vacuum. After that if that fixes the brake problem then find a vacuum source that is full vacuum at idle off the carb. Then install the trans line to it.
  28. PeggySue
    PeggySue
    The fitting on the manifold is 3/8", will try it
  29. greybeard360
    greybeard360
    The hose you have connected to the booster is coming off of a one way valve just like the one on the booster. The hose on that valve should be going to manifold vacuum. The way you have it connected.. you aren't getting vacuum in the cannister.
  30. 41rodderz
    41rodderz
    from Oregon
    Definitely do what Jim told you. I was wondering why you put such a small booster on that car. Small 7 inch are great for small or light cars but I think you have the space. See if a 9/10 inch dual diaphragm booster would fit. 70s Monte Carlo , Chevelle's came with bigger than what you have. Good luck.
    bobss396 likes this.
