How bad will hooking my map sensor and transmission modulator valve on the same source hurt engine or tranmission performance?? I'm running a Big Stuff 3 ECU on an Enderle 8 Stack converted to efi.
Well, Rod, you've come to the wrong place. This forum is ofr questions and suggestions about the operation of the HAMB, not car questions. Now, if you go to the HAMB (Hokey *** Message Board), and where it says "New to the HAMB? Introduce yourself here, and post an intro, then go to the HAMB with your question, someone will provide some sort of an answer for you. Good Luck. Mutt
