Technical Vacuum switch source
Discussion in 'The Hokey Ass Message Board' started by Gasolinedeniz, Sep 9, 2014.
  1. Because of my cam i have to run a vacuum pump for my brakes. I got one out of a Audi. My problem is i cant find a vacuum switch to control the pump. Anyone has a source for it?
  2. txturbo
    txturbo
    What do you need the vacuum switch to do?
  3. switch on /off the pump on low vacuum
  4. junk yard kid likes this.
  5. mgtstumpy
    mgtstumpy
    Local compacts over here with diesel engine (Isuzu) had a vacuum pump on rear of alternator. Many small Japanese trucks do similar. That's a pace to start. Good for blower engines.
  6. thanks a lot for all the answers, cool :)
  7. Never mind about that Eci unit.
    Production problems
  8. stimpy
    stimpy
    honeywell still makes hobbs switches and in vacuum applications some are adjustable some are OEM apps ( found several delphis to be hobbs made) , if you know what the pump was out of go to rockauto.com and see if they sell it ( look under switches and brakees as sometimes its listed under one or the other or both also look under european versions of the car too ) or if you know the part number type it in as sometimes there search function will cross reference it, found many a weird item over there
    as for hobbs allied electronics carries there products
  9. stimpy
    stimpy
  10. gotit
    gotit
    Get a belt driven pump off a diesel. 7.3 powerstroke had a small unit that never went bad. The electric ones are noisy and quit every so often
  11. rramjet
    rramjet
    They make adjustable vacuum switches for controlling lockup torque converters in automatic transmissions. Might need to use it to control a relay depending on how much current your pump draws.
  12. Yeah ;) what he said ^^^
    The first link in post 4 might help you too
  13. Max Gearhead
    Max Gearhead
    from Wisconsin
    Hey Deniz, check your PM's.
