Hot Rods Valley Custom 32 in page headers.
Discussion in 'The Hokey Ass Message Board' started by Joe Blow, Sep 15, 2021.
  1. Joe Blow
    Joe Blow
    As the ***le states, this is about one of the pics that pop up as a header at the top of the of The HAMB pages.
    Searched to find if this has been has been mentioned before with no luck.....so hope this is not one of those dreaded "Do a search - this has been covered before." threads.;) If I missed a thread on it....apologies.
    I ran into this browsing around and thought it is pretty rad to see where this car ended up. Some may be aware of this and some may not......either way, it's cool.
  2. Moedog07
    Moedog07
    A cool bit of history. Thanks for posting it.
    Joe Blow and Stogy like this.
  3. 19Fordy
    19Fordy
    Thanks for posting that historical preservation.
  4. Max Gearhead
    Max Gearhead
    from Wisconsin
  5. garage2small
    garage2small
    The person who put that film together is Ben Kahan who is only in his early 20's and has made several outstanding short films about hot rodding, several having to do with HAMB qualified cars. He certainly has the lineage to do it. His dad is Aaron Kahan a member of the Choppers, his grandfather is a lifelong hot rodder, and his uncle is Robert Williams the hot rod artist. Check out the work of this talented young man on his You Tube channel 4 Speed Films.
  6. Stogy
    Stogy
    :rolleyes:...is this the same Hotrod?...if it isn't it sure as heck was inspired by it...
    Cool Thread Great Hotrod...
    Joe Blow and Speed Gems like this.
  7. Stogy
    Stogy
    Joe Blow likes this.
  8. Joe Blow
    Joe Blow
    Good find @Stogy, looks like I did miss one.:) Not sure on the frame, the video was all I found with any info on his ownership of this car. Yeah, I figured he was a member here too.
    Stogy likes this.
  9. 19Eddy30
    19Eddy30
    from VA
    I say No , The 32 ( staging) the rear fender are higher (right a belt line)
    Where the Red 32 with white walls ,rear fender looks to be 3-4 inch lower
    Stogy likes this.
  10. Stogy
    Stogy
    Your probably correct Red...I did note the rear fender looked lower to the belt-line but thought it may be optical due to light and angle, both have cowl vents removed and it seems there were frame swaps along the way...I'm gonna say I'm fencing it for now...Perhaps someone can identify the Deuce I shared or have another angle of same...a rear 3/4 shot would put things into bigger and better perspective...
    This Pic Below from the Link I shared shows how much things can change based on light and angle...
