Hey guys i was wondering if some of you could give your opinions on what this motor is worth. Was last run in the late 60s and sealed up. I cant get it to turn over yet, put some pb blaster in the cylinders today. I know it will need a rebuild but it was bought from a friend that did seal it up back then so i know that nothings broken internally. It is mostly complete, i have the generator, starter, water crossover and pump. I also have the steel flywheel with clutch and pressure plate. As a bonus i have a schiefer aluminum flywheel and an offenhauser trans adapter for gm. So what is a good price for all of this? Thanks
