Technical Valve adjusting A/B banger
Discussion in 'The Hokey Ass Message Board' started by Zottel, Aug 3, 2025.
  1. Zottel
    Zottel
    Can someone refresh my brain .... what was this rule 1+8... 2+7.....???
    The one you measure the other you can adjust....
    Not sure if it was this or 6+2... 7+1 .... wrote it down somewhere...und forgot where:rolleyes::confused:
  2. jaracer
    jaracer
    It would be nice to know what it is you are working on.
  3. Budget36
    Budget36
    ***ume a Model A engine?
    I don’t know the procedure, but a better topic ***le may help.
    At the top right of you post is “thread tools”, click on it to edit your ***le.
    Ie a “banger”
    Is 4 cylinders, so can be confusing.
  4. Zottel
    Zottel
    Everybody who knows... knowswhat I'm talking about... I just can not remember if the outcome had to be 9 or 8.
    Im 400 miles away from my shop and wanted to help a friend on the phone but did not want to confuse him more....
    You can measure at one lifter and the other you can adjust..... this rule tells you which ones are "couples"....
  5. cal1320
    cal1320
    from Florida
    The rule of 9. #1 valve open, adjust #8. #2 open, adjust #7.
    Or: intake valve almost closed, adjust exhaust of same cyl. Exh valve begins to open adjust intake of same cyl.
    rusty valley and Zottel like this.
  6. Zottel
    Zottel
    Thanks! So it was the rule of 9 ! Not of 8...
