Valve adjustment
Discussion in 'The Hokey Ass Message Board' started by Merc0Matic, Jan 18, 2015.
  1. Merc0Matic
    Merc0Matic
    from california
    Can someone tell me the proper valve clearance for a 350 sbc? Thanks
  2. What kind of lifters? Solid or hydraulic? Hydraulics are set at zero lash plus a quarter turn of the nut
  3. Merc0Matic
    Merc0Matic
    from california
    They're hydraulic, thanks
  4. flamedabone
    flamedabone
    And, don't forget that the lifter you are adjusting must be on the base circle of the cam.
  5. aaggie
    aaggie
    If the engine is not running then rotate until the lifter is on the base circle and rotate the push rod with two fingers while tightening the rocker nut. When you feel the push rod get tight turn the nut 1/4 turn.
    If the engine is running and warmed up, back off the rocker nut until it starts making noise then tighten it down 3/4 of a turn.
    The beauty of hydraulic lifters is that they are not real precise.
