Hot Rods Valve cover paint question
Discussion in 'The Hokey Ass Message Board' started by harleycontracter, Mar 29, 2018.
  1. harleycontracter
    harleycontracter
    I just painted a pair of older Edelbrock script valve covers black to match my motor. I want to remove the paint from the surface of the scripted letters. What the best way? Thought sand paper, razor blade etc... It's a small are just don't want to screw up the rest of the paint doing it. Any tricks to do it?
  2. N2hotrods
    N2hotrods
    I use my large belt sander with a 220 grit belt works great
  3. MAD 034
    MAD 034
    from Washington
    Lacquer thinner on a rag works well
    lurker mick and slowmotion like this.
  4. BJR
    BJR
    I use thinner and a rag, after the paint has tacked off.
  5. harleycontracter
    harleycontracter
  6. Deuces
    Deuces
    Yep! Lacquer thinner and rags.... How about some pictures when your done????... Thanks!
  7. harleycontracter
    harleycontracter
    Have you guys used thinner on the fins or the script too? Painted them this afternoon will it still work after it's dried?
  8. Atwater Mike
    Atwater Mike
    Yes, fins and script alike. BUT! (and it's a 'big' but) Suspend a piece of OSB or cheap pinewood (a board, 4" wide or more) above you. Run it from a shelf to a ladder, attach the valve cover to it with drywall screws from underneath.
    NOW go at it with the lacquer thinner on a rag, overhead. Lacquer thinner won't run down on your background paint this way.
    Gravity only '****s' when you lay stuff on it. Or let lacquer flow down onto your work...
    wackdaddy, wraymen, oldsjoe and 6 others like this.
  9. BJR
    BJR
    Now that's a GREAT idea!!!!
  10. hotrodA
    hotrodA
    Somewhere on here I saw a tip about using a thin piece of chamois instead of a rag.
    No fuzz, fits tight on your finger, no drips.
  11. oldsjoe
    oldsjoe
    Lacquer thinner on an old sock works now add what a****er Mike said and it might be easier! Joe
  12. Rich S.
    Rich S.
    I just found a valve cover on the other side of the street. Is it yours?
  13. Deuces
    Deuces
    Once it's done right, it should look something like this here... CHROME-LIKE-POLISHING-VALVE-COVER-260.JPG C-455-10.jpg
    fauj likes this.
  14. Rich S.
    Rich S.
  15. HOTRODPRIMER
    HOTRODPRIMER
    Lacquer thinner soaked rag wrapped around your finger works great.
    Deuces likes this.
  16. mountainman2
    mountainman2
  17. southcross2631
    southcross2631
    Getting ready to do mine today . I painted my old M/T valve covers with VHT wrinkle paint. Will post photos When finished.
    pat59 likes this.
  18. southcross2631
    southcross2631
    Here they are before and after. Used a razor blade to get the major portion of the paint off. then went over them with 320 sandpaper. 20180329_160744.jpg 20180331_152108.jpg
    Deuces likes this.
  19. Cerberus
    Cerberus
    It just so happens today I purchased wood craft sticks (tongue depressors) from Michaels Craft Supply Store. I use contact cement to adhere sandpaper to them for sanding small items, and my 140 lb Rottweiler's toe nails. This idea would work great on your valve covers.
  20. Deuces
    Deuces
    Sweeeeeeeeeet! :)
  21. 41rodderz
    41rodderz
    from Oregon
  22. Deuces
    Deuces
    Yeah, them 409 valve covers look like fine jewelry... :cool::D:cool:
