This Man Cave Table Lamp has been created as follows: The Shade was made with 2 Small Block Chevy Valve Covers, polished, and hold one light bulb each. The center of the top is a 6210 Holley Carburetor with Billet Aluminum Air Cleaner that has an Engine Turned Top. The Stem is a Cam Shaft, Tig Welded to a 7" Steel Plate with 4 Main Caps Tig Welded to make the base. The Cam, Base, and Carb Plate are Heat Blued and clear coated. The Carb is painted Black and Silver. Stands 28" tall x 18" wide. Contact us at innovativedesignspecialties@gmail.com if you are interested for shipping cost.
