Technical Valve seal issues
Discussion in 'The Hokey Ass Message Board' started by BillSchmid, May 30, 2018.
  1. BillSchmid
    BillSchmid
    from Ohio
    I am having issues finding a valve seal that will fit my 062 vortec castings. I had originally planned on running comp's positive seals, but the tool I used to cut the guides to .530 had a defect and the seals are too loose to hold on to the guide. As a solution I bought fel pro ss72527 intake and ss72526 exhaust umbrella type seals. The exhaust seals have plenty of clearance, but the intake won't clear the guides. I guess my question is can I buy another set of exhaust seals and use them on the intake side? Or does anybody have any solution? I would hate to have to cut the guides more, but that may be my only option as most umbrella seals I see online look to big to fit inside my z28 style springs. Here are some pictures to help give a visual. The second picture is the positive seal that is too loose and the third is the frl pro that doesn't have enough clearance. IMG_20180530_115103460.jpg IMG_20180530_115114406.jpg IMG_20180530_115151953.jpg IMG_20180530_115214508.jpg
    Sent from my XT1635-01 using The H.A.M.B. mobile app
  2. Chappy444
    Chappy444
    full disclosure: i am no master engine builder...but i have rebuilt a few SBC's (327/350) and i don't recall ever having different seals for intake and exhaust (same thing on the few motorcycle engines i have done)
    I would say that the valve stem (top side) doesn't care if it is intake or exhaust. the seal just need to stop oil from running down the stem. get some more of the ones that fit, ****on it up and run it.
    just my 2 cents worth.
    Chappy
  3. BillSchmid
    BillSchmid
    from Ohio
    That is what I was hoping to hear.
  4. onetrickpony
    onetrickpony
    from Texas
    Lots of mid 80's Chevys used a positive Viton seal on the intake and an umbrella on the exhaust. When I worked as a machinist, I would often use the umbrellas on both intake and exhaust when we were out of the others. No one ever came back with a problem. Lots of Fords and other GMs used umbrellas on both intake and exhaust.
  5. Engine man
    Engine man
    from Wisconsin
    You won't have vacuum on exhaust valve stems anyway but they might get hotter than the intake stems.
  6. BillSchmid
    BillSchmid
    from Ohio
    Thank you guys. I am just going to order another set of three exhaust seals and call it a day.
  7. yellow dog
    yellow dog
    from san diego
    You should be fine with umbrellas on both .....Looking at the picture though, it appears that the spring seat may not be flat between old and new machine work. Does the outer spring have a consistent contact surface? Inners?
  8. BillSchmid
    BillSchmid
    from Ohio
    You are correct. The arbor for the cutting tool used to machine the guides down wasn't straight and the seats are not entirely flat, though I stopped as soon as I started into the seat so not by much. Would this pose an issue? Should I run a shim to be on the safe side?
  9. yellow dog
    yellow dog
    from san diego
    Bummer....I guess the question is how bad are they. a few thousands measured down from the retainer might be OK.
    If you are wary, you might take the heads in and just get the spring pockets cleaned up. You must already have some
    shims to achieve the recommended ***y height/seat pressure, but that may not square the spring. The extreme worse
    case might be uneven guide wear and early spring fatigue due to loss of heat transfer. You've probably seen slomotion
    videos of spring motion, but take a peek. Not that you are running those RPM extremes quoted.
    . On the seal issue, I wouldn't have any qualms. I began not
    using any seals years ago when having inner spring clearance problems and only recently started using vitons
    on the intakes. No negatives, not even upon cold startups.
  10. BillSchmid
    BillSchmid
    from Ohio
    Well that blows. They aren't the full diameter of the spring and none go very deep, but they aren't even from one valve to the next. I will probably just do shims since this is just going on a mild 327 for a daily driver that will never see any real high rpms.
  11. BillSchmid
    BillSchmid
    from Ohio
    I suppose it is a lesson learned not having the machine shop cut the guides for me while they decked the heads.
  12. yellow dog
    yellow dog
    from san diego
    Yep, so maybe it won't go 100K. I remember using Isky's seat cutter in the 60's with a hand drill....not pretty.
    The worse thing is probably the mental image held in memory.
  13. jimmy six
    jimmy six
    Whatever you do don't use the red ones from Compe***ion Products. They break apart and clogged up the oil pump screen. I had to remove all the valve gear and springs while still on the engine and then take off the pan. I found pieces of the spring clips like what is on the lower half of the the dark blue one above. They were on Dart Iron heads with double springs set to #135. I installed a single big block spring #145 and seals with metal only on the guide. So far so good.
